Best equipment to create and maintain trails
   / Best equipment to create and maintain trails #1
Dougryan
Webster, NY
Cub Cadet 3206
Hi,
I'm new to rural living... actually not even in the house yet, but closing dates are set and planning to move in October.
I'd like to, and I have mapped out using Google maps, create a mile long trail on my property.
It consists of old corn fields and woods. The ground is very bumpy and uneven and I'd like to smooth it out so that I can run with minimal risk of ankle twisting.
I've been looking at compact tractors with box blades, but there may be a better step to do first... Perhaps using a york rake to break up the ground and expose rocks that can be removed from the trail surface? Or would a box blade with scarifiers do the trick?
Also, for a good finish, I believe some type of V shaped drag would be ideal to create a crown vs pushing soil to the outside of the trail.
Ideas, thoughts, experience?
Thanks,
Doug
   / Best equipment to create and maintain trails #2
The park district used a mini dozer to blaze trails…
   / Best equipment to create and maintain trails #3
+1 on @ultrarunner's advice. As someone who has built lots of trails, rent a dozer to do the initial work. It is safer and more effective than tractors. If you know that you have rocks, I would make sure to rent one with scarifiers. Try to rent a dozer no larger than the final trail size.
After that, yes, a tractor with a tilting box blade and scarifiers should be fine. You probably don't want a land plane as trail design is to shed water on a slope at the trail, and not channel the water anywhere, unless you have a need to fill a pond or something like that.
Have fun!
Peter
   / Best equipment to create and maintain trails #4
Maybe add wood chips to the trail instead of digging into it.
   / Best equipment to create and maintain trails #5
I've spent this summer widening my trails. However wide you want them, make them 50% wider. The sides will grow in and the tops will droop down (with heavy snow). If you can weave between the trees and have no stumps, then I think a disc and a drag would be the tools of choice (best for the corn field in any case).
If you will have stumps, then a bulldozer is step 1.
My trails are for ATV riding and hunting, so I just cut the stumps off close to the ground and keep mowed with a Rotary (rough cut) mower, I use the Huntstand phone app to map the trails on our 80 acres.
   / Best equipment to create and maintain trails #6
Tree roots can stop a tractor and can tear expensive things up.
   / Best equipment to create and maintain trails #7
mulcher. I used to dozer the trail open and maintain it with a rotary cutter. Now I just use the CTL and mulch everything in my path. Use it for trail upkeep as well, as more often then not, a tree can be found fallen across the trail.
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A55788)
2009 Peterbilt 384...
2005 Dodge Caravan Van (A55853)
2005 Dodge Caravan...
2016 FREIGHTLINER CASCADIA (A55745)
2016 FREIGHTLINER...
2008 Chevrolet C4500 (A53314)
2008 Chevrolet...
2018 HINO 338 KNUCKLE BOOM TRUCK (A51406)
2018 HINO 338...
2012 SOUTHERN 130BBL VACUUM TRAILER (A53843)
2012 SOUTHERN...
