Best CUT attachment for this kind of earthmoving?
   / Best CUT attachment for this kind of earthmoving? #11
Box blade,ground must be dry.
   / Best CUT attachment for this kind of earthmoving? #12
I've got my first ever tractor arriving soon! (Kubota B2301). I've got a FEL and 4 in 1 bucket coming with it, as well as a rotary hoe. No other attachments as yet.
I know FELs aren't bulldozers, and I've read the warnings about not abusing your FEL when earthmoving in this thread. I'm determined to do a bunch of earthmoving with it though, thought I understand I will have to take it slow. I really don't want to prematurely destroy my tractor in the process. So I could use your advice!
One of the major tasks I'll be doing is to re-landscape some grassy fields: I want to slice off some ~2'-4' high spots and use this to fill in some low points. We're talking a high spot which is say 30'x30'...so not just smoothing little lumps and bumps in the field. It is all presently covered in grass too. The soil is a clayey basalt, with occasional stones of varying sizes.
To tackle a job like this, I understand from reading the above thread that it could be done by taking it very slow, a few inches at a time, with a tooth bar attached to the bucket. I haven't bought a tooth bar yet. What I'd really like to know is, should I consider using some other attachment for this kind of work? Am I better to run a middle buster or something like this through it a few times, and then use the loader to shift the loosened soil? Would a box blade be a better investment than a middle buster? Maybe I need both? (I have a gravel driveway to maintain, too). What about a back blade or something else?
Any advice or tips appreciated!
A box blade with ripper teeth is the only suitable tool, without damaging your very small machine.
Pushing that stuff is bulldozer work!
Maybe plan on 4+ full weekends, with a box blade on the B2301!
   / Best CUT attachment for this kind of earthmoving? #13
I suggest getting rid of the grass first as best you can. Scalp with a mower, burn, Roundup, or whatever method you have at hand. I agree that's a lot to expect from your tractor.
   / Best CUT attachment for this kind of earthmoving? #14
You won't like this.....rent a dozer or hire someone with a dozer that knows what he is doing. You will be astonished at what a dozer can accomplish in a few hours. I think you will regret investing in the 4in1 bucket. I had a guy with a JD550 come in last year to do some work, What he did in 2 hours would have taken 2 days, but I also had trees to deal with.
Get a landscape rake for finial leveling after the dozer is done.
   / Best CUT attachment for this kind of earthmoving? #15
When doing that type of work I simply hit it with the tiller, peal off the soft tilled soil with the loader then till it again/repeat .
Makes it easy loader work and gives you nice, easy to work with soil for filling in the low spots.
Sorry, what I have ordered with my tractor is a rotary tiller: RTZ Series – Kubota Australia
It sounds like this might be the best tool to loosen the soil anyway.
I'm tempted to get a box blade too, like some have suggested, also because I'll likely find lots of other uses for it (and it sounds like pulling a box blade is far less stressful on a tractor than pushing or pulling with a FEL...is that correct?)
   / Best CUT attachment for this kind of earthmoving? #18
THAT IS CORRECT !!!
A tractor is designed and built to PULL !!!
   / Best CUT attachment for this kind of earthmoving? #19
Going to second the hydraulic top link idea, best money I've spent on my tractor
   / Best CUT attachment for this kind of earthmoving? #20
Best thing about a box blade is being able to lower the rippers and criss-cross an area to break it up w/o having to drag any around. That said, whether I disc, sub-soil, chisel plow, or other I like the landscape rake to spread and level what's been loosened up.
If there's a lot of greenery and roots, I drag off later what's surfaced/dried with the rake or chisel plow. Stir it up a little to let more dry and repeat a few times. Spread the work over dry days, get a feel for efficient passes, get a lot done with patience vs beating up a machine.
btw, tiller can easily wind up with roots. Scalping prior and/or Glypho w/two weeks to shrivel can help to minimoze that. Always till at a crawl and change directions for repeat passes. (you knew that :) )
2019 Isuzu NRR 1,200 Gallon Fuel Transport Truck (A56858)
2019 Isuzu NRR...
Informational Lot - Shipping (A56438)
Informational Lot...
Toro Sand Pro (A56859)
2018 Ford F-150 Pickup Truck (A56858)
2018 Ford F-150...
Niagara No. 46 Shear (A59213)
Niagara No. 46...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A58214)
2008 V.E...
