Best catagory 1 quick hitch ?
   / Best catagory 1 quick hitch ? #1
wbyman
What is the best catagory 1 quick hitch ? Northern tool has an adjustable Catagory 1 Nor-track for 120.00 plus shipping, and it comes with the attachment the Harbor Frieght do not come with. I have several different implements for food plots so I need one, all my implements are under 10 years old. Thanks !
   / Best catagory 1 quick hitch ? #2
I love the JD I-Match, but its spendy and really works only with I-match attachments.
   / Best catagory 1 quick hitch ? #3
You will eventually be disappointed in the frame-type quick hitches.
Look into the Pat's for usefulness with several different kinds and brands of attachments.
   / Best catagory 1 quick hitch ? #4
Don't know if it's the best or not but I have one from Harbor Freight and it's served me well.
M.D.
   / Best catagory 1 quick hitch ? #5
I have Pat's, but it does not work with the Kubota ballast box that I have for the B3200 :(
   / Best catagory 1 quick hitch ? #6
Don't know If it could be the best but i have A TSC that is built quite heavy duty and the welds are done quite good. Comes with quick hook and link along with two bushings for one attachment. Have had it for two years and use it with Woods RFM, 72 Rake and 72" Land Pride BB.Quite Satisfied with it.B3200 TLB
DevilDog
   / Best catagory 1 quick hitch ? #7
Could you go into details why it did not work?? I'm thinking about Pat's but if it doesn't work on everything... forget it.
   / Best catagory 1 quick hitch ? #8
I have a HF quick hitch....and I have Pats. I removed the HF hitch and gave up on the %^&$%^%^ thing.......its sitting in the corner of my garage. I like my Pats. It fits everything quite nicely (except an old Dearborn Plow).
I would recommend the Pats EZ Hitch to anyone....ESPECIALLY if you have lots of implements and / or make frequent changes in implements.
   / Best catagory 1 quick hitch ? #9
I like the Carters, for the price, and simplicity, and you dont have to worry about PTO shaft length. as it is on top of the arms not behind them.
James K0UA
   / Best catagory 1 quick hitch ? #10
I have a Woods quick hitch. It works with my snowblower, back blade, tiller, middle-buster, brushbull cutter.... I never take it off. BEST thing I own...
2803 (A50460)
2803 (A50460)
2015 Toro Z Master Professional 64in Zero Turn Commercial Mower (A50322)
2015 Toro Z Master...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
Kinze 3500 8 Row Vac Planter (A52349)
Kinze 3500 8 Row...
KJ (10) Rolls of Hot-Dip Galvanized Field Fence (A50121)
KJ (10) Rolls of...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
