Best ATV sprayer
   / Best ATV sprayer #1
LabLuvR
SC
Kubota MX5400
I need to plant some food plots and have about 10 acres I will need to spray. Any of you fellas have an ATV sprayer that you really like? Thanks!
   / Best ATV sprayer #2
I just bought 2 ATV sprayers from Northern Tool. They probably offer a dozen different models. The ones I got (bought 2 of the same unit) come with 30' of hose and a gun type sprayer that is capable of spraying a fine mist, a cone pattern, or a loose stream up to 30' high. They were $269 each. I looked around a lot and liked those the best of what I saw, but I will say I have NOT used them yet. I'm mounting them on a custom 3pt carry all unit to use behind my tractors. I also got spray booms for the rig as well so I can drive and spray or use the gun sprayers.
   / Best ATV sprayer #3
This is a re-vamped ATV sprayer. The booms are home made and give a 10' wide spray swath. The tank is 15 gal.
Spraying Par III it takes 1 litre per tank / per acre and takes about 1/2 hour to spray. Just a idea if you are looking at spraying 10 acres.
   / Best ATV sprayer #4
The biggest problem I had with my 15 gal ATV mounted sprayer was in the weight...I was trying to use a Suzuki 160 2wd, and the weight of the tank filled made it so the front wheels were just barely touching the ground, and were useless in trying to actually turn the thing. I'm guessing one of the bigger ATV's would have no issue with this. I ended up mounting the ATV sprayer on a pallet attached to a rear 3ph carry all...
I guess i could have used my son's heavily tweaked 300EX quad, that thing flat out FLIES...plus I could have gotten done alot quicker!
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
1987 FRUEHAUF 8,000 GAL TRAILER (A53843)
1987 FRUEHAUF...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
Kuhn FC 4000 RG (A50123)
Kuhn FC 4000 RG...
John Deere WG48A 48in Walk-Behind Mower (A51691)
John Deere WG48A...
12 in Large Excavator Bucket (A52377)
12 in Large...
