Best Attachment for Removing Rocks
   / Best Attachment for Removing Rocks #1
Hook
Milford, NJ
Kubota L3010
We have an area on our property that is about 3/4 acre, I'm guesstimating. It is full of rocks, ranging from gravel sized to grapefruit sized. I'm thinking that a landscape rake would be the best attachment for clearing that area of rocks.
Is that correct? Or is there something better I could use?
Hook
   / Best Attachment for Removing Rocks #2
IF you can find a place to rent one, get a power rake it will remove the stones from the top 2"-3" and leave the soil redy for grass seed
Kevin
   / Best Attachment for Removing Rocks #3
Those grapefruit sized rocks might be a problem for the landscape rake. I have a similar situation and just ordered a tooth bar for my loader bucket. I thought by rolling the bucket with the teeth in close contact with the ground(rocks) I should be able to unearth them and place them in the bucket for removal. I'll let you know how well it works in the Spring!
Boomer33
   / Best Attachment for Removing Rocks #4
There is an attachment called a "rock picker". Depending on the number of rocks that are grapefruit size, this also might be a good solution. I know they are very expensive to purchase - and you may be able to rent one.
EC
   / Best Attachment for Removing Rocks #5
I use a landscape rake.
   / Best Attachment for Removing Rocks #6
Another option is a scarifier/landscape rake combo, such as the Landpride SF2566-77 and 25 series rake. These implements can be used separately or in tandem.
<font color=green>stan</font color=green>
   / Best Attachment for Removing Rocks #7
Since I can't afford the right tool for this job I have the best luck with the landpride pulverizer. I can rake them to one spot and then what the loader does not scoop up leaves alittle hand work.
Poster: DDT
Subject: Re: Best Attachment for Removing Rocks
And what would the "right tool" be?
Hook
   / Best Attachment for Removing Rocks #9
2025 IR UNUSED Cleanout Bucket (A53117)
2025 IR UNUSED...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A53473)
John Deere 6105E...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
HOMEMADE 4' X 12' SINGLE AXLE TRAILER (A51248)
HOMEMADE 4' X 12'...
2011 Kubota ZG222 (A50123)
2011 Kubota ZG222...
