Best 4n1 bucket for JD 400x loader
   / Best 4n1 bucket for JD 400x loader #1
SCDolphin
Columbia, SC
Kubota L5240: Craftsman GT6500
I am looking at the 4000 series JD with 400x loader. Can anyone recommend the JD 4n1 vs aftermarket like W.R. Long brand.
Thanks
   / Best 4n1 bucket for JD 400x loader #2
Hugh,
As we discussed, I have had the JD 4n1 bucket on my 4000 series. It is very nice. I did not like the bucket actuation quite as much as my nieghbor's Long bucket on his 4320. They seemed to be built about the same. The Long bucket is a smidge more pricey, but not by a lot. The long bucket has its trade off's as well, mainly in that the hydrualic apparatus to actuate the toggle and lines run to a remote cylinder mounted just off the right loader arm. It looks a little unfinished and busy to me, but works fine. My tractor had the third scv lever that allowed you to open/close the loader and the joystick did everything else; th Long bucket can have all functions through the joystick and toggle, which is a slicker setup. In short, there is not too much difference between them, but I would give a slight edge to the Long bucket, for the reasons noted.
John M
   / Best 4n1 bucket for JD 400x loader #3
Couldn't you guys get away with forks to do most of the things you want the 4in1 to do? A 4in1 is nice but I had one and was disappointed that I couldn't get stumps and brush high enough to load a truck efficiently. With the forks I get the height and more reach. It also ended-up bent and bowed and a greasy, heavy mess... Just something to consider...and considerably less dinero too...
   / Best 4n1 bucket for JD 400x loader #4
I have a Long UJ1 which seems to have more capacity then the Deere model. It also weighs a little more so it is stronger. I agree the lines around the valves are untidy and can get snagged.
   / Best 4n1 bucket for JD 400x loader #5
Dave,
I agree with you in many ways here. I had a JD 4n1, and while I liked it, I did not have it that long. When I sold my 4520, and ordered another 3720 which has not arrived yet--I did not order another 4n1. Maybe down the road, but for my uses it did not help me that much (although it was neat to have). If I were buying one for homeowner or light/medium duty use, the JD would be a nice choice. For commercial use I think the Long would be a better choice. It is heavy duty but does not seem to hold as much. One could buy quick interchanging attachments and not get a 4n1 I think too.
John M
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2019 John Deere 1023E Tractor (A51573)
2019 John Deere...
2001 John Deere M665 (A50120)
2001 John Deere...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
UNUSED SWICT 66" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 66"...
