besides tractor, anyone own a skid steer? will it tear up the lawn?
   / besides tractor, anyone own a skid steer? will it tear up the lawn? #1
playboybill
john deere 4200
Hello Everyone, I have a john deere 4200 1998 and i recently started having engine problems with it. its beeen used a lot! so, my friend has a bobcat for sale and ive never owned one, so i was wondering if any of you have?
The question i have is, I do a lot of tree work and things where im on customers lawns....The John deere is minimal damage with the turf tires i have on there so it was nice....im wondering though, since bobcats are a skid steer will they tear up the lawn a lot more? I have a z-rider mower so i know about not pivoting and making wide turns when cutting the grass..but never owned a bobcat...so is this possible to do okay on the lawns if i know how to use it the rite way? or no matter what their going to tear up? thanks everyone.
   / besides tractor, anyone own a skid steer? will it tear up the lawn? #2
Yes, kind of. And yes. My neighbor had a Mustang Skid steer and it tore everything up but did lots of work quick, about twice as quick as a tractor with the same size FEL. Another good friend 1 mile down the road has a BobCat and its just as bad. Good part is I can borrow it when needed and he uses my log splitter in return.
Either get your tractor fixed or get another one with turf tires to protect the customers lawns.
Chris
   / besides tractor, anyone own a skid steer? will it tear up the lawn? #3
My JD 7775 can make a wide-wide-wide turn on the aphalt driveway and still leave a rubber trail. I wouldn't dare put it on my lawn.
   / besides tractor, anyone own a skid steer? will it tear up the lawn? #4
I have an old case 1845 on my farm. I would say that if you take it easy and turn very gradually (like with your Z-turn) you should do ok, but yes, the skidsteer will be more prone to damage lawns than your tractor
   / besides tractor, anyone own a skid steer? will it tear up the lawn? #5
I have a Deere skid steer as well 36 HP.
It will tear up the lawn far more than the tractor.
OTOH it will run circles around the tractor in productivity.
   / besides tractor, anyone own a skid steer? will it tear up the lawn? #7
My experience is that they will do significantly more damage to a yard. There are definitely things the skid steer can do better than the tractor. We use one with a grapple frequently but on several occasions had to come behind it with a box blade to straighten woods roads to knock out the ruts created from turning in a small area.
   / besides tractor, anyone own a skid steer? will it tear up the lawn? #8
Straight in straight out you are okay. In some factories skid steer tire marks are a big cause for concern. Plywood was used there. Offer a rent to own week and see what it does around your place. The all -wheel steer will be a useful feature, but not alot of them sold.
   / besides tractor, anyone own a skid steer? will it tear up the lawn? #9
Welcome to TBN:D
Everyone else addressed the SSL issue-it sure will tear things up! They don't call them Skid Steer's for nothing;)
Now, what is wrong with the 4200? The Yanmar engines in those are pretty bulletproof. What is doing? How many hours on it?
   / besides tractor, anyone own a skid steer? will it tear up the lawn? #10
In a word-yes! Consider that most skid steers will typically weigh 2-4 times as much as your 4200. Then remember how they turn versus your 4200. If the ground is wet you'll get even more damage, especially when turning. And you'll probably find it's almost impossible to make wide enough turns to not see some turf damage. If you've got helpers, laying down plywood will avoid most of the problems.
GGB
1980 TIGER TA KILL TRAILER (A53843)
1980 TIGER TA KILL...
2008 Ford F-450 Crew Cab Service Truck (A52377)
2008 Ford F-450...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A55218)
2024 BCL...
SET OF (4) ALCOA 24.5 ALUMINUM RIMS (A53843)
SET OF (4) ALCOA...
Utility Trailer (A52377)
Utility Trailer...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
