Berta Two Stage Snow Blower Auger gear box oil change
   / Berta Two Stage Snow Blower Auger gear box oil change #11
I used to--and still think that no drain plug is a bad idea for maintenance minded people. I can modify that opinion now since I have discovered the Harbor Freight suction gun (see post #7) with small diameter tubing. I two recent applications I have drawn out the equivalent of what was the fill capacity is.
The trouble I envision with this, real or perceived, is that a drain plug allows any solid particulates (metal filings) to be swept out with the fluid, when draining a gear box or oil pan. But by using suction, it seems more likely a large part of any such solid particulates will remain in the bottom of the gear box.
But I've also never griped about draining a snowblower gearbox. Stand the thing up on it's front end, like I describe on page 1 of this thread, and pull the plug! That fill plug is a drain plug, depending on which way you tilt the implement.
Generac 11kW Natural Gas Generator (A55851)
Generac 11kW...
MCELROY COOL PACK 20 (A55745)
MCELROY COOL PACK...
2018 KENWORTH T270 SERVICE TRUCK (A57192)
2018 KENWORTH T270...
2017 Jeep Patriot 4x4 SUV (A53424)
2017 Jeep Patriot...
2024 JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
2024 JOHN DEERE 8R...
2007 Heil Heavy Duty Aluminum Tank Trailer (A55314)
2007 Heil Heavy...
