BERMXBL-62b
/ BERMXBL-62b #4
looks like you might have to remove the fel sub frame.
/ BERMXBL-62b #5
Hoe 4pt is at the sides, blade/blower subframe runs in the middle from front to back, 4pt should stay. Hoe and FEL gets taken off... [ uneducated guess ] [ you can leave the FEL on if you want to ride around with it sticking up in the air all winter...... ] [ and you can leave the hoe on if you really want.. ] :)
/ BERMXBL-62b
Thanks for the info guys. I guess I just wanted to know if anyone has a set up like this and is it worth $2500.00 I know the FEL has to come off as that is what powers the up/down and angle of the blade. i don't mind taking the hoe off but I'm not into removing the hoes sub frame or 4 point (new to the tractor thing) Is it true... he who dies with the most attachments wins... i might have to make a shirt that says that!
/ BERMXBL-62b #7
Don't think I'd want to be removing any subframes either. That would be quite a job on my machine. In fact I'd go shopping for something with a skid steer mount so I'd just have to remove the front bucket. There has to be something like that out there somewhere. I'd probably remove the backhoe and will but not it's subframe for pushing snow around.
/ BERMXBL-62b #8
i use my fel and that works - no need for other stuff for my scenario - but could see a readon if needed. but removing all the subframe is WHOA!!!! no way! **** i do not even remove my fel when midmower is on. just not going there. fel is used 99% of the time so why remove and sub assembly - no no no way!
UNUSED ATS POWER ATS-PC90 HEAVY DUTY PLATE COMPACT (A64281)
UNUSED ATS POWER...
2015 Nissan Leaf Hatchback (A61574)
2015 Nissan Leaf...
Caterpillar 214-224 Wheel Type Excavator Service and Parts Manuals (A63117)
Caterpillar...
2022 EZ-GO ELITE...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
43024 (A59228)
43024 (A59228)
