Benye Hyd Pump
/ Benye Hyd Pump #1
MattMih
Wilcox, SK
Case 646
Chinese tractor Benye304-16
Does someone know where I can get a replacement for this pump? See attachment.
As far as I can tell the part is GS-12-R-YT and made by TJ
thank you
Matt
/ Benye Hyd Pump #2
Affordable or Circle G may be able to help
Amazon has as seller from china Timeway that with the correct info may be able to help.
These that are pictured are the newer design pumps but I think will mount up.
My Rhino has the same case style as what your Benye has. I considered upsizing the volume for faster hydraulics , but haven't pulled the trigger.
Volume, spline, rotation direction, case size and style, are in the code- see the final diagram in the linked amazon ad, it shows how the code corresponds to the pumps specs.
Hope this helps, I did not find any direct links for Benye Pumps.
/ Benye Hyd Pump
Thank you. Circle G has one very close. I am contacting them for measurements etc. The shaft is square. Thank you very much for your feedback.
NEW Landhonor LHR-AIW1  1" Air Impact Wrench  (A62679)
NEW Landhonor...
ROANOKE S/A LOOSE LEAF TRAILER (A63291)
ROANOKE S/A LOOSE...
Location Tampa, FL (A61567)
Location Tampa, FL...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
2025 IRANCH IREAS Wood Grab Grapple Mini Excavator Attachment (A61572)
2025 IRANCH IREAS...
2019 JOHN DEERE XUV560E GATOR (A64280)
2019 JOHN DEERE...
