Rotary Cutter Bent Rotary Cutter Blade
   / Bent Rotary Cutter Blade
Indy,
Yeah, I think that is what probably happened. And you're right about it not being for the faint of heart. Ever been going down-hill when the stump jumper hits a stump and bounces the cutter about 4' off the ground? With the angle of the hill, the cutter looks almost verticle rising up behind you. /forums/images/graemlins/shocked.gif
Hobby,
The scratched paint and dents give it character. /forums/images/graemlins/grin.gif
   / Bent Rotary Cutter Blade #12
Mr. Leather Neck, I think you're using the bush hog too rough:)) Just from an old ARMY man.
David
   / Bent Rotary Cutter Blade #13
So, how much torque did it take to remove the nut? I see your big socket and extension. Just wondering if you had a breakover bar or used an air impact.
Kyle,
If you look close in the first picture, you can see the impact wrench. It is rated for 650 FT/LB loosening torque and 550 tightening. 1/2" drive using a 3/4" drive socket and adapter.
   / Bent Rotary Cutter Blade #15
Wow!
My blades tend to bend up, rather than down... probably due to repeatedly bashing half buried rocks. It's generally not as dramatic a bend as yours. After a time, it does tend to allow the blades to slam up into the underside of the deck the next time I hit a good rock.
Anyone had any luck straightening these back out? I'm wondering if it's worth trying to put it in a hydraulic press.
John Mc
2025 Swict 78in Bucket Skid Steer Attachment (A53421)
2025 Swict 78in...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
2023 JOHN DEERE 325G SKID STEER (A52707)
2023 JOHN DEERE...
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
2019 WACKER NEUSON CORPORATION DBA WACKER NEUSON LIGHT TOWER (INOPERABLE) (A55745)
2019 WACKER NEUSON...
Club Car Electric Cart (A55758)
Club Car Electric...
