Bent PTO shaft
   / Bent PTO shaft #1
cubstuff
Is there anyway to straighten or otherwise repair a PTO shaft that has been bent while in use? Seems as if part of the quick hitch on the tractor was hitting the PTO shaft while it was spinning. Thanks.
   / Bent PTO shaft #2
Try this.
<A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showthreaded.pl?Cat=&Board=parts&Number=127465&Search=true&Forum=All_Forums&Words=bent%20PTO&Match=Entire%20Phrase&Searchpage=1&Limit=50&Old=allposts&Main=127465>Bent PTO</A>
   / Bent PTO shaft #3
It most likely depends on how it is bent. If it's bowed its worth a try with a vice and a ball peen hammer. If its dented, I doubt it.
   / Bent PTO shaft #4
Once a shaft like that has been bent, it's very difficult to get it back right. Not that it can't be done, it's just hard, and usually expensive compared to the cost to replace. If you straighten it and don't get it right, the vibration will substantially shorten the life of the u-joints and probably the bearings supporting the PTO output shaft at the tractor.
Dave
   / Bent PTO shaft #5
Most PTO shafts are tubing and would be difficult to straighten and
get it true.
Other problem is if it will slide after your done.
TSC and other farm stores have the blank tubing.
U might be able to replace it and save the ends.
Some are welded together and others are pinned or press fit.
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2007 MACK CT713 ROLL OFF TRUCK (A52141)
2007 MACK CT713...
Case International MDX91 3pt Disc Mower (A50774)
Case International...
1982 LeeBoy Motor Grader (A52748)
1982 LeeBoy Motor...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
Как зайти с телефона на кракен. kra39ac.cc  | Kraken зайти на площадку? как пополнить кошелёк? Правила диспута
Как зайти с...
