Bent PTO shaft
   / Bent PTO shaft #1
BKColeman
Virginia
TC 40D w/ SuperSteer
I just got my new rotary cutter two weeks ago. I have been struggling to get the PTO shaft to telescope in and out. So I took it apart tonight to grease it, and I believe it is bent. I'm going to call the dealer in the morning to have him look at it, but I thought I would ask the experts here if it does indeed look bent. This is my first pto powered implement so I don't want to call him if I'm wrong.
So what do you think? Doesn't this look bent? I put a level beside it as a straight reference. Or are they supposed to look this way?
Thanks,
Brad
   / Bent PTO shaft #2
Brad,
It's bent. Probably because it was to long when the deck is raised.
Al
   / Bent PTO shaft
Here's another view.
Thanks for the advice.
--Brad
   / Bent PTO shaft
Al, thanks for the fast response. That's impressive service.
I thought so, I'll give the dealer a call in the morning, glad he's the one who cut the shaft in the first place.
Thanks,
--Brad
   / Bent PTO shaft
Glad I asked. Thanks Inspector.
--Brad
   / Bent PTO shaft #7
It will vibrate something awful..............could tear up a seal at the least
   / Bent PTO shaft
Jerry,
Where could it tear up a seal at? I'm asking because the other thing I was going to talk to the dealer about is I have a small leak I think near the rear end of the tractor. I haven't found the leak yet, I just noticed a wet spot on the floor tonight.
I have only used the rotary cutter once and there wasn't any real vibration, but it did shear the shear bolt when I first engaged the PTO (which now makes sense). I called the dealer about that over the weekend and he said it didn't sound right and if it kept happening he would come to take a look. That was before I realized it was bent.
Thanks for the feedback. Your wisdom is appreciated.
   / Bent PTO shaft #9
Could damage the seal on the gearbox of the cutter or the seal at the PTO shaft
   / Bent PTO shaft #10
<font color=blue>...glad he's the one who cut the shaft in the first place...</font color=blue>
Brad...
I'm not familiar with the Top Link Bracket on the TC40... but if you have the top link mounted in the "bottom" hole and raise the cutter all the way up in transport position (also check the lift pin placement on the cutter)... (without looking and raising it too high)... you... may have bend the shaft unintentionally when it came in contact with the front of the rotary cutter deck and bent it... /w3tcompact/icons/frown.gif
Another PTO shaft assembly will run you ~ $140-200... I really don't think the dealer will "eat" this one.../w3tcompact/icons/sad.gif (but if he does... you better take him out to a few dinners... /w3tcompact/icons/smile.gif)
2008 Jeep Wrangler Unlimited X SUV (A53117)
2008 Jeep Wrangler...
25077 (A51694)
25077 (A51694)
Unused 2025 MS380 Mini Track Loader Skid Steer (A51691)
Unused 2025 MS380...
2023 ARMOR LITE TRAILER BELLY DUMP TRAILER (A53843)
2023 ARMOR LITE...
2025 K0520 UNUSED (5) Welded Wire Mesh Roll (A53117)
2025 K0520 UNUSED...
