bent power steering piston
   / bent power steering piston #1
ktm250rider
Anyone ever straighten the cylinder piston? Ive bent my power steering piston on my 4510. Been like that for some time but I would like to fix it. Its bent enough to leak fluid very slowly. New piston from Deere is about $500. Or, is the shaft perhaps replacable?
   / bent power steering piston #2
All parts are replaceable. My local hydraulics shop fixes many of them. I was lifting a telephone pole out of the ground woth a Case 580 when one cylinder sent the piston out on a very curved mission. The damage was limited to the piston and was repaired quickly at far less cost than a replacement unit. Check around .
   / bent power steering piston #3
I assume you mean the cylinder rod is bent and the rod packing is now out of shape and leaking. I would change out the cylinder complete since by the time you round up the individual parts (if available) there won't be much to save.
Steve
   / bent power steering piston #4
As Joe mentions in above post if you have a hydraulics shop that can do the work then by all means get an estimate and compare.
Steve
   / bent power steering piston #5
While pushing snow I drove off a wall and broke my steering cylinder shaft. I checked all the cylinder repair shops in my area and all told me the same thing. Buy a new one. On the 4310 (I suspect the 4510)there is no repair for the cylinder as the tractor was manufactured with a welded cylinder. On the bright side, the new one is rebuildable. I think mine was $430 two years ago.
If you find someone to repair yours let me know as I still have my broken one.
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
JOHN DEERE 8R310 TRACTOR (A54756)
JOHN DEERE 8R310...
(12) 2" X 6" X 41" TUBING (A54756)
(12) 2" X 6" X 41"...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A52706)
2001 INTERNATIONAL...
20ft. Deer Gate (A53424)
20ft. Deer Gate...
