Bent my rake, now what??
/ Bent my rake, now what?? #1
TSMART
central florida
jinma jm 224
On the last swipe of the day, I backed into a small tree and bent my rake. If I remove all the tines and take this to a heavy equipment shop, could it possibly be bent back?
/ Bent my rake, now what?? #3
I try heat large hammer/pipe wrench for bending,but if number tines are damage might be wise as you suggested.
/ Bent my rake, now what?? #4
Ouch! Might take appart and put in a press. I have worked on angle like that before and get close to orig. specs. with a 20 ton hydraulic shop press. (You know, the ones that use the bottle jacks.) They work great to straigten out lower link arms, bent A frame members, and pressing in u-joint crosses!
Tons of uses..... (Pun intended.) :D
/ Bent my rake, now what?? #5
I second the press. Everything I have ever heated bends back.
Chris
/ Bent my rake, now what?? #6
Or consider buying a piece of angle iron, and drill the holes to make a new piece. Local welder may be able to blow off the top bracket and weld it back on your new angle. Just another option you can toss around.
/ Bent my rake, now what?? #7
I second the new piece of angle iron approach. Bending etc will get it close but never quite the same -- JMHO
/ Bent my rake, now what?? #8
I straighten angle iron cold all the time. Get yourself a couple of big old Stillson (monkey) wrenches and a couple lengths of pipe for cheater handles. Those wrenches will take a solid grab on the web and you can work one against the other or just one against the piece held in a solid vise. You'll probably need to overbend by about 10% to accommodate the "springback" effect but you can do it. Better to do it cold than hot since you're not softening the steel that way. The re-bending will actually work harden it a bit and make it tougher some times. With some care, you may not even have to remove more than one or two tines.
Rich
I removed all the tines and took it to our local heavy machinery shop. They put it in a press.
Cost $25....but it's good as new.
Thanks for all the suggestions. I was pretty ticked off at myself for messing up, especially in the last 2 minutes of a long day on the 224. MUST get some kind of rear view mirror....
/ Bent my rake, now what?? #10
$25.oo for repair and now ready for action..fair price indeed.
"messing up"
More than fair share of us been there,and will continue to makes oops years to come. ;)
/ Bent my rake, now what?? #11
Education costs money, sounds like you got off pretty cheap:) Wish I was so lucky, my "learning" usually puts a large dent in my wallett...
/ Bent my rake, now what?? #12
Glad to see the press worked. I bought mine from Harbor Freight on sale. It has saved me $$$ and is a lot easier to work than having to don the heavy gloves and get out the acetylene torch and rosebud tip, 3 lbs. Engineer's hammer and anvil. It usually gets the job done.
Machine shop sounds just as handy without the investment of capital and having a place to put a press.
Best Regards,
Bart
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
2009 CHEVROLET 3500HD 4x4 PICKUP TRUCK (A59912)
2009 CHEVROLET...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
2014 VOLVO A40G WATER TRUCK (A62129)
2014 VOLVO A40G...
Butler MFG Water Tanker (A63689)
Butler MFG Water...
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
