bent lower link lift arm
   / bent lower link lift arm #1
tcreeley
Elite Member
Hudson, Maine
2003 NH TC30
The TC30 lower left link lift arm was bent - quite a bit on one side. I looked it up and NH had it for 160 or so and TSI for 30-40 for a generic Ford arm. I tried straightening it with the bucket and lifting front end up off the ground. That didn't work. So I overhung the ends on 2x4's and hit the bend with an 8lb sledge hammer. That was a bit slow but did the job. Saw sparks maybe 2-3x. Put it back on - looks good. Of course it is a bit weaker now - but not a big concern.
   / bent lower link lift arm #2
can always buzz a piece of angle on it.. that's practically a 'band-aid' for a ford.. :)
soundguy
   / bent lower link lift arm #3
My though the same Soundguy. The lower arm needs a piece of permanent splint welded on or it will bend again there. The fix is simple if the op has access to scrap pieces, a port-a-band, a welder and 1/2 hr time.
JC,
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2018 FREIGHTLINER...
John Deere Hsld 2510 H Nh3 Applicator (A50514)
John Deere Hsld...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
2014 PETERBILT 367 (A50854)
2014 PETERBILT 367...
2015 MACK GU713 (INOPERABLE) (A50854)
2015 MACK GU713...
HONDA EU2200EI INVERTER GENERATOR (A50854)
HONDA EU2200EI...
