bent lower link lift arm
   / bent lower link lift arm #1
tcreeley
Elite Member
Hudson, Maine
2003 NH TC30
The TC30 lower left link lift arm was bent - quite a bit on one side. I looked it up and NH had it for 160 or so and TSI for 30-40 for a generic Ford arm. I tried straightening it with the bucket and lifting front end up off the ground. That didn't work. So I overhung the ends on 2x4's and hit the bend with an 8lb sledge hammer. That was a bit slow but did the job. Saw sparks maybe 2-3x. Put it back on - looks good. Of course it is a bit weaker now - but not a big concern.
   / bent lower link lift arm #2
can always buzz a piece of angle on it.. that's practically a 'band-aid' for a ford.. :)
soundguy
   / bent lower link lift arm #3
My though the same Soundguy. The lower arm needs a piece of permanent splint welded on or it will bend again there. The fix is simple if the op has access to scrap pieces, a port-a-band, a welder and 1/2 hr time.
JC,
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
MCELROY 500 SERIES 3 TRACKED FUSION MACHINE (A50854)
MCELROY 500 SERIES...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
GENERAC MAGNUM LIGTH PLANT (A50854)
GENERAC MAGNUM...
