Bent lift arm, d*** it.
/ Bent lift arm, d*** it. #1
studway
Bronze Member
Anyone ever replaced a bent 3-pt lift arm on a BX? How much for the part, how hard was it, etc.?
I was using a 7' sickle bar on an old tractor today when the tractor died. I had to take the sickle off before we could tow the tractor to the garage. I figured I could put the sickle on the kubota just to get it back where it belongs. I attached one arm and the top link, then lifted the 3-pt a bit to line up the other arm. When I did, the whole sickle bar swung around about a foot and just twisted the lower arm that was attached. I managed to get the other side on anyway and got the sickle out of the way.
/ Bent lift arm, d*** it. #2
I actually have no idea what a new one will cost, but if they're like most, you'll probably want to consider a big hammer and an anvil to straighten the old one.
/ Bent lift arm, d*** it. #3
The blue tip wrench will likely be in order.....
Phil
I may try staightening it out. I guess worst case it just bends again and I'll need to buy one. I'll try to post a picture tomorrow, it's quite twisted.
/ Bent lift arm, d*** it. #5
studway
I laid mine in an big girder that I use to drag my road, a couple of pumps with porta power in a few spots it was close enough now if it twisted a couple of pipe wrenches might be in order to un twist it
tom
Couple of pipe wrenches with pipes on the handles would do the trick. Thanks for the tip.
/ Bent lift arm, d*** it. #7
I pounded mine with a 16# sledge and got it pretty straight. The part part on my L is $158.56 at Tractorsmart.com.
/ Bent lift arm, d*** it. #8
I'd say you need somewhere to hold it well and a bloody great hammer.
2019 CATERPILLAR CP54B PADFOOT ROLLER (A62129)
2019 CATERPILLAR...
2019 FORD F-150 XLT CREW CAB TRUCK (A63276)
2019 FORD F-150...
Push Type Weed Eater (A64127)
Push Type Weed...
2016 JOHN DEERE 7210R TRACTOR (A64280)
2016 JOHN DEERE...
2022 SANY SY50U EXCAVATOR (A63276)
2022 SANY SY50U...
QA Pallet Forks (A64127)
QA Pallet Forks...
