Bent King Kutter
/ Bent King Kutter #1
HickoryDean
New Orleans
Kioti LB1914
For 3 years have used 4' KK with hitch bar attached to 1914. Then when backing up while bushogging, the blades suddenly started hitting the hitch bar. The vertical bars that form an upside down "Y" are bent forward. Decided to take everything topside apart and reverse the bars. That didn't work as the angle braces that extend from the rear wheel mounting point to the vertical bars now extend way past the bolt holes and the short angle braces prevent the verticals from moving far enough forward. It's a mystery how the long angle bars still reach the verticals. No indication that the deck itself bent.
2 questions: Should I replace the vertical bars? Is it cost effective to replace the blades? Appears I would need 1" drive rachet and 1.5" socket to remove blades...probably a dealer job. Any advice would be greatly appreciated. Using "as is" is an option except now have bad vibration possibly caused by blade imbalance from having hit the hitch bar.
/ Bent King Kutter #2
I would suggest you ask a moderator to move this to the ATTACHEMENTS forum, many members do not visit the Kioti forum so you may find that by posting a question about an implement in a brand specific forum that you won't get many replies.
208320 (A58375)
208320 (A58375)
2007 Sterling L9500 Fuel & Lube Y22693 (A62613)
2007 Sterling...
2006 Ford F53 Landau 3645DS 36ft. Class A Motorhome (A61574)
2006 Ford F53...
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A60430)
2017 KALMAR OTTAWA...
2006 Chevrolet Silverado 2500HD Ext. Cab Knapheide Service Truck (A61573)
2006 Chevrolet...
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
