bent hydraulic cylinder???
   / bent hydraulic cylinder??? #1
Diamondpilot
Super Star Member
Daleville, IN
Jinma 254/284 Ford 861 Powermaster at work
Hey guys.
I was abusing my 7 year old tractor trying to pry some 8" and bigger stumps up. Anyway I bent one of the curl cylinders slightly. It now has started to leak. I ordered a gland kit for $25 to rebuild it but want to know about how to straiten the piston rod.
The cylinder is a 1.75"x24" stroke cylinder. The piston rod is 1" in dia and the bend is so slight the pictures I took do not show it. I laid a metal strait edge on it and in its 24" length its out about 3/16" to 1/4" max. Its really a bow more than a bend and its right in the middle of the piston rod.
Thanks
Chris
   / bent hydraulic cylinder??? #2
I had luck putting a cylinder in a shop press, supporting it from either end and applying force to the peak of the bend. Make sure you put a buffering pad (I used aluminum sheet) so you don't mar the cylinder rod.
   / bent hydraulic cylinder??? #3
I agree I did the same with mine once, I applied pressure to go just beyond the straight mark and then when released it was straight enough to use.I used the same packings etc. and no lead .I do have it in the back of my mind now and 'favor' it more than the others..Its worth a try ...
   / bent hydraulic cylinder??? #4
That's all good & fine but you also have to use a dial indicator with V blocks. Roll the rod between them w/dial indicator to see if you've got it straight. Otherwise your just guessing and probably wasting your time.
   / bent hydraulic cylinder??? #5
Hey guys.
The curl cylinder should be under tension in that situation , not compression , it should not have bent . Are you sure it does not foul the arm when the bucket is fully dumped ?
   / bent hydraulic cylinder??? #6
Hey guys.
Thanks
Chris
Chris,
not sure what part of Indiana you located in but would suggest you take this cylinder to a repair shop that is set up to either straighten or replace the rod. Presuming your existing rod is Chrome plated there is a chance that the chrome is cracked and even if straightened will in time flke off. These chrome chips are like razor blades and will eat bearings, seal etc. Also if not straight it will wear out the rod bearing.
If you are close to Chicago there is a very good repair shop in Elk Grove Village: Universal Hydraulics ask for Tom @ 847/228-5750.
I have no affiliation with them, just have used them in the past to repair cylinders.
If you are close to Indy or any other major town I would suspect they also have cylinder repair centers.
Roy
It does not hit but I was also working the tractor back and forth in the creeper gear, very slow at 60' per hour at WOT, while pushing on the stump with the cutting edge of the bucket. It may have happened some other time but was noticeable after I tried using it as a dozer.
Chris
Thanks for all the suggestions guys. I have a shop press and a hydro shop a few towns over. I will live with it for a week or so before I take on this job. Worst case a new cylinder is $240 plus shipping.
Chris
   / bent hydraulic cylinder??? #9
I straightened the power steering cylinder on my tractor by using a 2X4 and turning the wheel. It stopped leaking too. I'd take a stab at using the tractor hydraulics to straighten it before buying a new cylinder.
Great idea. This can be easily accomplished against the loaders frame. I will try it later today or tomorrow. I bet I can get it close like you did.
Chris
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
New/Unused AGT MX-CRT23 Mini Skid Steer Loader (A51573)
New/Unused AGT...
THRESHOLD 30" SQUARE OUTDOOR GAS FIRE TABLE (A51248)
THRESHOLD 30"...
THOMPSON F4L 1011 PORTABLE DIESEL PUMP (A51406)
THOMPSON F4L 1011...
ECHO SRM-2120 GAS WEED EATER (A51248)
ECHO SRM-2120 GAS...
2016 TAKEUCHI TB290 EXCAVATOR (A51246)
2016 TAKEUCHI...
