Bent Draft Link
/ Bent Draft Link #1
snpower
Charlottesville, Virginia
John Deere GT235, GT 275, 1025R
Ugghh. These are around $175.00. Any chance it could be straightened out, or is there an aftermarket/generic replacement that would work for part LVA23630?
TIA
/ Bent Draft Link #2
Looks like a lower hitch arm to me and yes you can straighten it by heating with an oxy-acetylene torch and a small rose bud along with a 5 pound drilling hammer and a flat steel welding table or hydraulic press.
/ Bent Draft Link #4
If you take the draft link to someone for repair, take the good one with you also. Then who ever does the repair will have a pattern/ out line to follow. Opposite hand/ mirrored image etc.
/ Bent Draft Link
Thanks for the input, everyone. I took both links to my local and trusted auto shop and they made it as good as new - at no charge.
/ Bent Draft Link #8
Not telling what you did to bend it like that? If known, others may be able to avoid the same.
/ Bent Draft Link
I'm trying to compose it properly and add a picture :)
So I have a Heavy Hitch, with 8 40+ pound weights which was/is attached to the three point using Pat's system. I believe a I did not quite have the retaining clip (see photo) set in place correctly which allowed one side of the Heavy Hitch to slide up out of the sytem. I was digging out some stumps, with my CRI stump bucket and I felt an impact as I was backing up. I turned around and saw one side of the Heavy Hitch on the ground. After I shut down and inspected everything I noticed the bent arm. I am not certain that is what happened but... pretty sure.
Lesson --> Just like with airplanes preflight your tractor :)
2004 John Deere 310G 4x4 Loader Backhoe (A59228)
2004 John Deere...
58in Hydraulic Side Shift Forks Skid Steer Attachment (A61572)
58in Hydraulic...
1996 Vermeer V-3550 Ride-On Trencher (A61572)
1996 Vermeer...
2025 Fendt 943 Vario Tractor (A63111)
2025 Fendt 943...
Kubota KX080-4 Midi Excavator w/ Hydraulic Thumb (A64047)
Kubota KX080-4...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63689)
2017 Yale GLC050VX...
