Bent Cylinder Rod
   / Bent Cylinder Rod #1
Believer
Can a slightly bent rod be repaired? If so, what is the procedure? Thanks.
   / Bent Cylinder Rod #2
Please post a few pictures of the "mess"...
Usually the procedure will end up with a visit at the MACHINE SHOP, and have the to make a new rod....so best advice is to take the rod to the machine shop before putting more damage into the rod......
If I would DIY it....take the cylinder apart, disconnect piston from rod....
I would use some straight hard wood lumber for bracing, and a hydraulic press (or a sledge hammer) ....then roll it on my granite kitchen counter top (which is 100% flat or it would be cracked) to check it is straight...
I think there are experienced hydr-shop guys here that can fill in with details
   / Bent Cylinder Rod #4
   / Bent Cylinder Rod #5
If on a loader, sometimes you can use the tractor hydraulics to straighten it w/o disassembly. A wooden v block to cause a pinch point as you articulate it.
larry
   / Bent Cylinder Rod #6
larry
Yep, worked for me one time on a backhoe cylinder.
MarkV
   / Bent Cylinder Rod #7
I know some of you guys have been lucky straightening them out w/o taking them apart, that's great....... but you do risk junking the barrel, gland and/or piston head......the safest way not to do anymore damage is to pull apart and straighten on hyd press.....use aluminum to protect chrome and a dial indicator for a visual so you don't overbend.......
Be carefull cuz some hardened rods do not want to be straight again.....
Don't ask me how I know!!!!!:ashamed:
   / Bent Cylinder Rod #8
I agree...take the cylinder apart first. You can rotate the rod in the
press to the best point (max bend) to place the force. It is not always
exactly perpendicular to the cross tube axis.
   / Bent Cylinder Rod #9
Agree! Take the suckers apart. False economy to try with them together.
On the hydraulic press, you need to bend PAST straight slightly to get it to stay straight. The bend back pretty easy. If you take care with the seals, you may be able to put it back with them. (I never could, but you might)
2007 Utility 3000R 53ft T/A Reefer Trailer (A51692)
2007 Utility 3000R...
2021 Bell B30E Off Road Dump Truck (A53117)
2021 Bell B30E Off...
Box Blade Pull-Behind Tractor Attachment (A51691)
Box Blade...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2003 Club Car DS Electric Cart (A51694)
2003 Club Car DS...
Zerex 50/50 Anti-freeze (A53117)
Zerex 50/50...
