bent a middlebuster/can it be welded
   / bent a middlebuster/can it be welded #1
pd444
North Florida
JD 990
Got hung up on a root and the horizontal member is bent. This happened because a weld supporting the horizontal bar and the weld at the top of the vertical bar/plow broke. Knowing virtually nothing about welding, can a standard weld shop bend this back and reweld it? I mean, I know they can, but will the metal be sound enough after having been bent. Also, any idea about how much this should cost?
Thanks!
   / bent a middlebuster/can it be welded #2
I would estimate about 30 min, and about $30
   / bent a middlebuster/can it be welded #3
you can likely straighten it with a bottle jack and a piece of chain.. then reweld.. scab a piece of angle iron on the member that bent if you are worried about strength.. paint er' yellow and likely no one will notice.. if they do.. mention that it is the new experemental HD model.. :)
soundguy
   / bent a middlebuster/can it be welded #4
when fixed and welded it will probally be stronger than the original. welders have a tendency of over building everything, which in the tractor business is a good thing.
   / bent a middlebuster/can it be welded #5
It looks brand new to me???
   / bent a middlebuster/can it be welded #6
I would say bend it back and weld it up. If you have a picture of the actual injured implement it would be easier to make specific suggestions. And we could all say: WOW look at that. The wonders or raw tractor power.
   / bent a middlebuster/can it be welded #7
can it be welded? Is it made of metal? OF COURSE you can weld it.
If you bent it, perhaps you might want to add scrap angle iron to box it in to make it stronger while you are at it to get it fixed. If the welder prefers not to bend it back and start with new metal- its fine- just have him beef it up for you anyways. Either way will work.
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
(11) 2 PLUG VALVES (A52472)
(11) 2 PLUG VALVES...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A52748)
UNVERFERTH 330 8...
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
2002 INTERNATIONAL 4400 BEVERAGE TRUCK (A52576)
2002 INTERNATIONAL...
378813 (A51573)
378813 (A51573)
