Bending telescopic stabilizer on 3pt hitch
   / Bending telescopic stabilizer on 3pt hitch #1
NRR
Albion, CA
Kubota MX 5000, Caterpillar D6C, Ford 1510
I am on my third telescopic stabilizers, every time I put our brush hog on I bend one of them. They had been installed uneven by a previous employee, I evened them out thinking I solved the problem, but yesterday I ran the brush hog and bent another stabilizer. Any input on what I am doing wrong would be great.
Thanks
   / Bending telescopic stabilizer on 3pt hitch #3
Somehow I recently bent one on my BX25. I thought I would have to buy a new one. But, I have a 20 ton HF press and thought what the heck, I have nothing to lose by trying to straighten it myself. Amazingly, I was able to straighten it like new. So, if you have a press or know someone who does, you may not be out of luck. And... good luck to you.
   / Bending telescopic stabilizer on 3pt hitch #4
NRR,
You probably already checked this, but if you haven't: Check the two pins on the Hog that get the snap rings. If one pin has a lot of play, it can give stress to the other. May sure the nuts are snug, both in and out.
Hope this helps.
   / Bending telescopic stabilizer on 3pt hitch #5
NRR, some pictures might help others visualize where and how the 3pt arms are getting bent. It would take something pretty extreme to constantly bend the arms like that. Examples I can think of:
a) Slamming into immovable objects with the cutter deck when turning.
b) Having too much slop in the side-to-side adjustment so the bush hog gets thrown back 'n forth hard as you mow.
I've been running a 6 ft. bush hog behind my Kub for more than 10 years now and the 3 pt. setup works like new.
   / Bending telescopic stabilizer on 3pt hitch #6
Both the telescopic stabilizers on my B2710 have also bent. I borrowed the stabilizers from my B3030 and they also ended up bent. I have no idea why they are bending but the mower does seem like a good suspect. I just pounded the stabilizers with a maul (not attached to the tractor, of course) and that straightened them enough.
   / Bending telescopic stabilizer on 3pt hitch #7
Thanks
Do you have the lift arms tight against the pin on the bush hog so the cutter cannot move side to side?
   / Bending telescopic stabilizer on 3pt hitch #8
I use mine pretty hard and have never had one bend.
But I do set them where the mower doesn't slam back and forth.
   / Bending telescopic stabilizer on 3pt hitch #9
I figure the way they work is that their strength is when force tries to stretch them. Mine have slotted holes that I try to utilize that so they don't see force trying to compress (and bend them).
   / Bending telescopic stabilizer on 3pt hitch #10
Thanks
Are the attachment pins DIRECTLY opposite from the lower lift arm attachment point?
SDT
2009 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2009 Ford F-250...
2017 Bomag BW90 AD-5 Vibratory Articulating Tandem Smooth Drum Roller (A50322)
2017 Bomag BW90...
Allied 760 Loader (A50515)
Allied 760 Loader...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2019 Ford F-450 4x4 Crew Cab Gooseneck 11FT. Flatbed Truck (A49461)
2019 Ford F-450...
2011 IC Corporation PB105 School Bus (A49461)
2011 IC...
