Bench testing starter, does this sound right?
/ Bench testing starter, does this sound right? #1
rholmes69
Zebulon, NC
Mahindra 2810
'03 2810, no symptoms of a failing starter, it just one day wouldn't crank. Made a 1/8 of a turn when the key engaged, then all lights flashed, needled bounced and when keyed off, it buzzed. Replaced battery, same symptoms. Checked the ground, cleaned, still good. Keying ignition would cause it to turn maybe one full revolution, then act like it jammed up on the compression stroke. Release key, try again, would maybe budge an inch; release try again and then it would turn maybe full revolution, repeat, etc, etc. I yanked the starter, pulled it apart, looks like brushes and armature visibly ok. Good contact on the carbon to the rotor, bearing and planetary gears spinning freely. When connecting directly on the bench, the starter turns, but it almost seems like it is slowly ramping up (initial speed is well over 100 rpm, it isn't spinning super slow, it just isn't hauling butt like I would think it would. I am used to them wanting to just torque themselves out from under your foot. This one is cranks up and it seems like the longer I leave connected to the battery, the faster it will start to turn. I have to remove the positive lead because it starts glowing pretty red and looking like it is going to "weld itself" onto the positive lug. Bendix operates normally
So cliff notes question, should the starter crank pretty hard when it fires up, like it would twist its way out of your hand or from under your foot? Is it normal for the starter to "ramp up" to speed?
/ Bench testing starter, does this sound right? #3
Did you check the bushings to make sure the armature isn't touching the fields?
I couldn't see any that it was touching the fields, although when I first pulled went to pull it apart, I couldn't spin the core by hand, so I guess it might have been... I have never rebuilt a starter before and really have limited experience messing with them... I use to help in a car parts shop and I remember bench testing starts back in the day, that is really the only experience I have with them. But I am a very mechanical person and have done everything except to completely rebuild a motor, so sometimes I am a little fearless when tearing into things when maybe I shouldn't :) ... stupid tax my wife calls it...
/ Bench testing starter, does this sound right? #5
How does the starter smell? When I troubleshoot electric motors the smell sense is my #1 tool.
Oh man, I don't know how it smells. I don't smell anything "burnt"....
/ Bench testing starter, does this sound right? #7
A DC motor (starter) should produce all of its torque immediatly. If it is ramping up to full speed something is defenitly wrong. If the terminal is glowing red that also indicates extremely high amperage draw. Is it worth fixing? Just wondering how much and how far out for delivery is a new unit?
/ Bench testing starter, does this sound right? #8
If you have a part # and make I can get the particulars for you, if its touching(poling)you should see the marks on either end of the armature, some times a simple bushing is all it takes. can you check to see if the nose piece fits snug on the drive end and same with the backplate on the ce commutator end.
/ Bench testing starter, does this sound right? #9
Thats exactly how it should act. Check the bearing/bushings. The armature is probably dragging.
/ Bench testing starter, does this sound right? #10
yup...you should barely be able to hold it when you hit it with the power.
2007 FRAC TANK 500BBL WHEELED (A63569)
2007 FRAC TANK...
Cat CB24B (A60462)
Cat CB24B (A60462)
2014 HYUNDAI 53X102 T/A DRY VAN TRAILER (A59910)
2014 HYUNDAI...
1997 Chevrolet Kodiak C6500 Aerial Crane (A62613)
1997 Chevrolet...
2014 JAYCO JAYFLIGHT CAMPER (A63569)
2014 JAYCO...
2004 Lincoln Navigator SUV (A61574)
2004 Lincoln...
