belts for Mahindra 575 di
   / belts for Mahindra 575 di #1
Michael Bryant
chatham louisiana
Mahindra 575 di
I am trying to find out what size the belts are for a Mahindra 575 di (water pump and generator). We don't have a Mahindra dealer in our area. The generator belt was destroyed so I couldn't get the number off of it to try and match one up. I think that this tractor is a 1995 model.
   / belts for Mahindra 575 di #2
if all else fails, mesure the width of pulleys at top. This will give you give you the top width (classifacation of the belt) then then loop a stirng around around all the pulley to get an idea of inside circumfrence. This will give an rough idea of overall belt width. Using the width and length you measured you should come within an 1" or so of correct width. Buy 2 or 3 belts close to that length, try them and return the ones that doe not fit.
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
2015 John Deere 825I Gator (RUNS) (A50774)
2015 John Deere...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A52748)
2022 Down2Earth...
2018 John Deere 460E Articulated Dump Truck (A52748)
2018 John Deere...
CFG Industrial STSD10 Grain Drill (A50121)
CFG Industrial...
2005 Toyota Tundra Limited Crew Cab Pickup Truck (A51692)
2005 Toyota Tundra...
