Grading Below zero - improvised snow blade trick
   / Below zero - improvised snow blade trick #1
snowbound
Westchester NY
NH TC35D
It's about as cold as it ever gets around here. The TC-35D started up with no problem.
On the other hand, the hydraulic quick disconnects seem frozen, and I couldn't budge them so I couldn't take off the plow to put the bucket on the loader. I could probably figure out a way to make that happen but it was too cold to hang around trying this and that. So I went over to what I was going to use the bucket for and figured out how to clear the snow using the plow in reverse to pull the snow out to where I could blade it away. It worked better than I thought it would - well enough to get the job done.
   / Below zero - improvised snow blade trick #2
Nice. I haven't touched my 33d in a week, had it out last weekend to scrape some ice (using the loader, works surprisingly well to rough the ice enough to drive over it..).. It complained bitterly in the 0 +/- temps..
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
2014 F-150 STX (A56435)
2014 F-150 STX...
Doyle Fertilizer Spreader (A56435)
Doyle Fertilizer...
New/Unused IRGC40 Mini Golf Cart (A57453)
New/Unused IRGC40...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2018 International WorkStar 7500 T/A Aquatech B-15 Combination Sewer Jetter Vacuum Truck (A56858)
2018 International...
