Grading Below zero - improvised snow blade trick
   / Below zero - improvised snow blade trick #1
snowbound
Bronze Member
Westchester NY
NH TC35D
It's about as cold as it ever gets around here. The TC-35D started up with no problem.
On the other hand, the hydraulic quick disconnects seem frozen, and I couldn't budge them so I couldn't take off the plow to put the bucket on the loader. I could probably figure out a way to make that happen but it was too cold to hang around trying this and that. So I went over to what I was going to use the bucket for and figured out how to clear the snow using the plow in reverse to pull the snow out to where I could blade it away. It worked better than I thought it would - well enough to get the job done.
   / Below zero - improvised snow blade trick #2
Nice. I haven't touched my 33d in a week, had it out last weekend to scrape some ice (using the loader, works surprisingly well to rough the ice enough to drive over it..).. It complained bitterly in the 0 +/- temps..
Portable Fuel Tank (A50515)
Portable Fuel Tank...
VOLVO L45G RUBBER TIRE LOADER (A51242)
VOLVO L45G RUBBER...
2018 CATERPILLAR 305E2 CR EXCAVATOR (A51242)
2018 CATERPILLAR...
(9) SHANK ALL PURPOSE PLOW (A51243)
(9) SHANK ALL...
2013 INTERNATIONAL MA065 CAB AND CHASSIS (A52472)
2013 INTERNATIONAL...
15KW Kohler Trailer-Mounted Generator (A52128)
15KW Kohler...
