Belly tank overlow on diesel generator
   / Belly tank overlow on diesel generator #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
Somehow, it just hit me. I'd put a piece of rubber (well, neoprene or synthetic rubber) tubing on the overflow/breather on the belly tank of my diesel generator.
Would a dobber plug this off? Or would the diesel smell deter him? What to do?
I put the tubing on it because I overfilled the tank one time and created a mess. The tubing comes up to where I've other tubing that I use to pump fuel out of the tank to fuel my tractor. Just a high point to keep fuel from coming out there, but it has to be able to suck fuel in when the general takes it out.
Wonder if they make something where one could put silica gel into it so that any air sucked in would be dried?
The 2nd one looks not unlike an inline fuel filter. Mine is under the cover for the generator.
Guess no one has had a dirt dauber fill the tube end.
   / Belly tank overlow on diesel generator #4
I have dobbers, they will plug ANYTHING,,,
how about a chainsaw/weedeater/Mantis tiller fuel tank filter?
There would be nothing to plug,,,
   / Belly tank overlow on diesel generator #5
I have a six foot length of 3/8 diameter hose used for siphoning fuel. The dobbers will plug both ends. I always have to rap both ends on something hard and blow thru the hose to clear the "dobber dirt".
   / Belly tank overlow on diesel generator #6
I would think that would work very well.
Aaron Z
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2009 IC Corporation PB105 Passenger Bus (A51692)
2009 IC...
2015 TAKEUCHI TB260 EXCAVATOR (A51246)
2015 TAKEUCHI...
2018 Komatsu WA380-8 Articulated Wheel Loader (A51691)
2018 Komatsu...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
Gravely 3000 RTV (A51573)
Gravely 3000 RTV...
