Mowing Belly Mower removal
   / Belly Mower removal #1
TNTYM
Johnson City, TN
TYM 233 HST
Hello - I have a TYM 233 with Belly mower - I would like to learn how to remove it and how to put it back on again? I bought the tractor used and the owners manual for the belly mower is incomplete. Any tips, guidance or techniques would be greatly appreciated.
TNTYM
hello Tractor Friends,
I need to replace a belt and blades on my TMB60SH belly mower. What I've learned so far is I need to remove the belly mower from the tractor to replace the belt.
That's my first step. I have been investigating methods for removing the belly mower and am looking for suggestions in doing this, should I jack up the tractor? can I drive over the deck? can I use the FEL to lift the tractor then block it?
Next, I plan to turn the deck upside down and use an impact wrench to remove blades. What specs does the impact wrench need to have?
Oh, by the way I was able to obtain a full owners manual from Dennis at Tractors on the Creek in Fairfield NC - he has been very helpful in learning about my TYM 233 Tractor. http://www.tractorsonthecreek.com/
   / Belly Mower removal #3
On my t233, i just turned the front wheels to one side and slid the mower out from under it. Disconnect the pto shaft, and unhook the deck lift cylinders from the deck, slide forward and remove the front bracket, rotate the rear deck wheels to the side, then slide it out. Between the front and rear wheels. You might be able to use the bucket to lift the whole front end off the ground but i havent tried it. DO NOT try to drive over the deck. Hope that helps!
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A52577)
2018 KENWORTH T680...
Toro Mower (A50324)
Toro Mower (A50324)
Polaris Side by Side (A50324)
Polaris Side by...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
