BELARUS tractor
   / BELARUS tractor #1
diggerman
canada
135MF ,265MF, 820 belarus
I have a hard time turning right with my 820 belarus tractor and have to put the bucket down then turn with is driving me crazy.The tractor wants to go left all the time so I have to fight with it to keep it going straight .just so you know The tractor has power assist .What could be the problem?
   / BELARUS tractor #2
I guess it's possible your diff lock is engaging under certain conditions. I have seen it where a slight turn to the right will engage it.
   / BELARUS tractor
well it just started working again out of the blue when I was working in 14 inchs of snow opening an old road when it just worked /forums/images/graemlins/shocked.gif. I wish I knew for sure what was wrong with it as I have to haul a load of hay from 6 miles away and there is lots of hills with deep ditch's on the way . I just don't want to start down a hill and have the tractor head for the ditch /forums/images/graemlins/frown.gif
   / BELARUS tractor #4
Sounds like a piece of trash (for lack of a better term) may have passed through the steering box. I bought a used tractor years ago and had pretty much the same thing happen. Only it was brief. I'd be going along and couldn't steer. Then it would start back working. I changed the hyd.oil and filter and never had the problem again. That doesn't mean you have bad or dirty oil. It could be an O-ring or part of a seal that let go and got in the system too. Then when it went through the steering valve it caused the problem.
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2006 FORD F750 XL SUPER DUTY SERVICE TRUCK (A51406)
2006 FORD F750 XL...
2011 GMC Savana 10FT Box Van (A51692)
2011 GMC Savana...
2013 Toro Workman HDX Scissor Lift Utility Cart (A51691)
2013 Toro Workman...
