Belarus 570 Clutch slipping??
   / Belarus 570 Clutch slipping?? #1
jimb111
North Alabama
Yanmar 3110d, Belarus 570 and International 444
Have a possible clutch problem with a 1997/98 570 with 450 hours. Was moving a round bale of hay today and as I started to climb a very slight incline, the tractor stopped pulling. I have not noticed any slippage or anything out of the ordinary in the past. A very very slight amount of torque can be noticed and a very slight slipping noise can be heard when the clutch is released. I did not smell anything like hot asbestos that could indicate slippage. The tractor goes into and out of gear normally. Anyone had a similar experience and what is the best method to isolate the problem. I know that clutch replacement would be very expensive and I do not want to pay to have the machine picked up and a clutch replaced until I am sure that is the problem.
Any advice and suggestions appreciated.
   / Belarus 570 Clutch slipping?? #2
Hydraulic or mechanical activated? Sounds odd that it quit w/o warning. Usually know you're gonna need one before it quits.
MMM,
The clutch is all mechanical linkage. You are correct that one would expect some sort of warning or slippage but the clutch had always worked perfectly. Maybe the problem is elsewhere but my first instinct is clutch.
Thanks.
   / Belarus 570 Clutch slipping?? #4
See if pedal height is correct when released(linkage bind). If there's a dust cover or access to housing(pull starter) see if there's evid of oil on flywheel.Might see if it will grind putting it in gear w/o clutch. Could be worse than clutch, like transmission, etc. Don't know much about Belarus options. Got shuttle reverse, powershift?
Thank very much gents, I located the problem and the keyed stub had fallen out of the axle. I used the differential lock to get to the shed, backtracked and found the key.
I welded a small bead on both ends of the key as a preventive measure to prevent future failures.
The clutch works fine.
The advice from all is much appreciated
2005 Ford F-250 4x4 Reading Crane Service Truck (A51692)
2005 Ford F-250...
LANESHARK LS3 LOT NUMBER 161 (A53084)
LANESHARK LS3 LOT...
2019 ExMark Lazer Z S-Series 72in Zero Turn Mower (A51691)
2019 ExMark Lazer...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2004 Capacity Yard Spotter Truck - Cummins Diesel, Allison Auto, Low Hours (A53472)
2004 Capacity Yard...
2020 KENWORTH T680 SLEEPER TRUCK (A52576)
2020 KENWORTH T680...
