Belarus 420AN
/ Belarus 420AN #1
missedagain32
texarkana
john deere
Guys I have been reading some stuff on here about them and its back and forth. I have a 33 hp john deere with a loader on it and its a great little tractor . It just doesnt lift much. I found this 420An with a bush hog brand loader for 1000. it runs but they said the clutch is slipping. I just need it to push around some heavy stuff and lift some bigger stuff every now and then. Would it be ok for this . I mean the price seems good enough. thanks for you help and time.
/ Belarus 420AN #2
Great price. My Belarus has been trouble free with occasional use.
/ Belarus 420AN #3
If you can really pick up a Belarus 420AN with a loader for $1,000, then you should do it today. I base this not on a Belarus being a great tractor, but that is basically scrap value (at least in my neck of the woods). Right now, we're getting right at $300/ton for scrap, and a Belarus 420 AN should weigh in about about 7,000 (heavy tractor), and I would bet the loader with bucket will add another 1,000 at least, so it's worth $1,000 sitting still.
I owned this same model (Belarus 420AN) for many years, and it certainly had it's issues, but it was not without its merits, either. Most of the problems were electrical, and if you can get handy with a spool of wire, some crimpers and a multi-meter, you can fix alot of those pretty easy. I think I had it for about 7 or 8 years, and it was overall a decent tractor.
If I had an opportunity to pick up a running Belarus, slipping clutch or not, for $1000, I would do it (again, you probably won't be out anything if it completely goes to crap). Besides scrapping, the bushog loader could probably bring $1000 by itself if you are patient.
Good luck and take care.
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 FREIGHTLINER...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59912)
2016 FREIGHTLINER...
2020 John Deere 8R280 (A64119)
2020 John Deere...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
Raven CR7 Monitor (A63117)
Raven CR7 Monitor...
Champion Vibratory Roller (A60462)
Champion Vibratory...
