Belarus 250as lift problems
   / Belarus 250as lift problems #1
roofmonster
Glencoe Alabama
Belarus 250as
I have a Belarus 250as
My 3-point stopped lifting.
The hydraulic reservoir is full and fluid pumps freely out of the bypass valve in the hydraulic distributor, I took off the hydraulic pump inspection plate and the pump is engaged, the lift cylinder only moves up about an but inch you can manually pull the lift up without an implement on when the lift distributor is engaged.
The hydraulic pump is engine drivin, has a fluid check plug but no fill plug?
Any advice?
   / Belarus 250as lift problems #2
If the other hydraulics work OK then this probably isn't the problem, however if there is nothing else on the tractor but the 3-point, then I would check the relief valve to see if it is stuck open.
Yes sir, nothing but the three point...Where is the relief valve?
   / Belarus 250as lift problems #4
Hydraulic pump check plug is also the fill point. Periodicly drain the pump then refill with the same hydraulic oil in the rest of the system (about 4 oz). I use an oiler with a flexible spout, available at most any hardware or tractor store.
14179 (A55788)
14179 (A55788)
2017 Dodge Ram SLT (A55314)
2017 Dodge Ram SLT...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
SOMERO S-222 LASER SCREED (A52707)
SOMERO S-222 LASER...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
