Belarus 250AS 3 point quit working
   / Belarus 250AS 3 point quit working #1
kyguy
250AS
Been maintaining the old thing pretty well. 3Point started sticking in whatever position it was in ocassionaly. Joggling the control would get it moving again. Now it has Quit working all together. So far" Cleaned filters, opened the footbaall plate on the hydralic control valve to flush that point out. Normally you crank the engine over and it flushes obstructions out of control valve. Now there is no fluid coming out at all. Took test plug out of Hydralic Cylinder and no pressure at all. And old post on here says Dual Compensator Spool could be the problem. If it is clogged you get no fluid flow so no pressure. Where is that located on the 250? Been over the pump and lines and dont find anything that looks like it. The problem appears to be plugged valve or bad pump. Dont want to order new hydralic pump wait a month for it and be back to square 1 when I install a new pump. I will appreciate any advice, even if you say Junk It.
6ft County Line Rock Rake (A48837)
6ft County Line...
2009 Suzuki Boulevard Motorcycle (A48836)
2009 Suzuki...
2009 KUBOTA KX080-3 EXCAVATOR (A50458)
2009 KUBOTA...
New/Unused 20ft Metal Farm Driveway Gate (A48837)
New/Unused 20ft...
ECHO SCHC 2620 25.4CC GAS SHAFTED HEDGE TRIMMER (A50460)
ECHO SCHC 2620...
Husqvarna 440 Chainsaw (A48837)
Husqvarna 440...
