KWentling
- Joined
- Jun 22, 2002
- Messages
- 1,192
- Location
- Rozet, Wyoming
- Tractor
- Kubota BX22, Kubota ZD21, Kubota M7060
So, two weekends ago, I rented a Cat 303.5 mini and dug about 500' of 6' deep trench for 3 new Woodford hydrants and a
curb stop for a future sprinkler system. I actually had planed on 800' and two more hydrants, but underground rock altered
that plan. I got all the polypipe, hydrants, and the curb stop in the ditch and it set open over the following week under pressure.
Had no leaks, but I did have the hydrants covered with washed rock and enough dirt to hold them upright so a small leak might have gone undected. I backfilled last weekend with the BX22 and used lots of water as I backfilled due to the extremely dry cloddy dirt.
Tuesday the wife hooks up her drip system up to one of the hydrants and ran it for about 48 hours. Now I have a wet spot showing
up at the lowest point of the ditch, which is also where there are two tees and one splice located. This particular hydrant had the set screw that raises the plunger loose from the factory, so when the wife opened it to bleed the air out, nothing happened. I closed the handle and tightened the screw and it worked, but might not be adjusted right. That hydrant has been off for 24 hours or so and the
wet spot hasn't grown so I'm thinking that hydrant is the culprit. Looking on Woodford's site it would seem that the only way it can leak out the weep hole with the hydrant on would be if the plunger is leaking. I wouldn't think that on a new hydrant, but who knows.
I guess the first thing to do is adjust the handle as instructed on Woodford's site. Then pull the head off and pull the plunger out and take a look. I have had to replace one of those in the past that looked good but leaked. I wonder if I could make up a pressure gage and hook it up to the hydrant, close the supply valve off, open the hydrant and look for the pressure bleeding off?
Any other ideas? If it comes to digging something back up, at least it will be easy digging for the little BX.
Kim
Kim
