Befco landscape rake?
/ Befco landscape rake? #1
houser52
Cherryville, NC
Kubota M7060HD, Kubota L3600
Anyone have any experience with Befco landscape rakes? I'm wanting something that's heavier duty than King Kutter or the one from TS. Just about everything around here is made for smaller tractors, 40hp or less. I'll be using it on a M7060 Kubota and want something that will hold up to pushing limbs and brush into piles so I can move them to the burn pile with my grapple. My 7060 is 71hp and Befco says their rake is rated for 65hp. I should be ok.
Before anyone suggests EA, I already called them and they're 11-12 weeks out. I also called several Land Pride dealers and everyone is out of stock with no deliveries for months. I need to get things cleared out before spring.
Thanks
/ Befco landscape rake? #2
Never had a rake from Befco, but they make some quality mowers. I've used a 7' rfm Befco for many problem free years.
/ Befco landscape rake? #3
I have a BEFCO grading scraper that has held up well. It seams to be built to withstand abuse. It was heavier than the LP but even still I wanted more weight so I have two logs on top of it. I was worried that the extra weight might stress the frame but after several years not a sign that it's not up to the task. I would buy another BEFCO piece of equipment if needed.
/ Befco landscape rake? #5
Thanks
I have had my 72 inch Befo rake with gauge wheels for 10 years only issue broke 1 rear tine other than that held up well.
/ Befco landscape rake? #6
I have had Ratchet Rake bucket attachments of two widths installed on my last two tractors.
I own a Landscape Rake from everythingattachments.com
The Ratchet Rake is far better at corralling limbs and brush relative to the Landscape Rake.
1. Your tool is in front rather than in the rear.
2. Debris does not hang up in the Ratchet Rake.
T-B-N ARCHIVE: https://www.tractorbynet.com/forums...-rake-today-fel-bucket.html?highlight=ratchet
VIDEO: https://www.youtube.com/results?search_query=ratchet+rake+brush+clearing
Thanks for the info. I went ahead and ordered the 72" Befco rake. It wasn't in stock but I'll only have to wait a few weeks to get it compared to waiting months on some of the other brands.
/ Befco landscape rake? #8
IMHO the Befco will serve you well for many years to come..
Thanks.
I've piled mountains of brush for over 25 years using a 5' King Kutter rake behind my 38hp L3600 and it has held up great, only had to weld it one time where a weld broke. I knew it wouldn't hold up to the bigger tractor is the reason for a heavier rake. Of course I'll still have the the 5' for smaller jobs.
2010 UE Manufacturing Armada 1000HP Single Pump Tri Axle Frac Blender Trailer (A64194)
2010 UE...
2007 Peterbilt 378 (A62679)
2007 Peterbilt 378...
2015 Nissan Altima Sedan (A64557)
2015 Nissan Altima...
New/Unused Landhonor Hand Chain Hoist (A65583)
New/Unused...
(35) Poly Feed Pans (A66408)
(35) Poly Feed...
2014 Caterpillar CB54B Articulated Vibratory Tandem Smooth Drum Roller (A64553)
2014 Caterpillar...
