Been looking for 5L Vee belt pully to direct mount on Hydraulic pump TAPER Shaft
   / Been looking for 5L Vee belt pully to direct mount on Hydraulic pump TAPER Shaft #1
CalG
Super Member
vermont
Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
NOT A TAPER LOC, Hydraulic pumps come with TAPERED Shafts (as well as straight and spline)
I'm needing a 4" diameter or so. I spent a few hours making up a taper by straight bore pulley adaptor, but don't want to go that way if I want to change pulley size in the future.
   / Been looking for 5L Vee belt pully to direct mount on Hydraulic pump TAPER Shaft #2
What size is the shaft? Most hydraulic pumps I work with are either straight shaft or splined.
B series pulleys would be what you need for a 5l belt.
Is the tapered shaft keyed? You can always buy blank pulleys and either get a tapered reamer, or turn a tapered on a lathe.
It's a 2 bolt A size pump with 3.25 mounting spigot. 18 mm shaft with a 3 mm key ( The world HAS gone metric.)
Sure, I can bore a taper into a blank, then cut the key. (HEY! I just did that today!) But why would I want to put $150 in time into a $20 pulley?
Pricing taper reamers will open one's eyes as well. And just how to specify? "Oh just make it to fit the hydraulic pump, I assume it matches the standard.
NFPA Mounting Flanges & Shafts for Hydraulic Pumps & Motors | Womack Machine
PS MOST pumps are not the pump I have, so that doesn't help. ;-)
from this, I assume there is no standard
TAPERED : HydraulicPumpStore!, Hydraulic Gear Pumps, Replacement Hydraulics, Piston Pumps
What pictures? What specs? I'm asking about pulley vendors!
   / Been looking for 5L Vee belt pully to direct mount on Hydraulic pump TAPER Shaft #6
I believe Browning used to offered tapered ID pulleys. I do not have a clue if they do anymore or not.
Do have a name or model number on the pump. Yes there are some standards for tapered shafts but I have no clue if every manufacturer uses the same standard or not. I.e. Vickers, Parker, Rexroth, etc...
Browning and woods is where I started. Just looked at Browning again, I didn't find in taper shaft finished bore pulleys.
But they exist! 5.5" DIA. 1 GROOVE A BELT PULLEY TAPERED BORE | Finished Bore Pulleys | Pulleys | Power Transmission | www.surpluscenter.com
They just are not available.....;-)
   / Been looking for 5L Vee belt pully to direct mount on Hydraulic pump TAPER Shaft #8
Do you have stores like Motion Industries in your area. They are a power transmission component distributor and may have a source for tapered shaft pulleys. Vickers power steering used to use these also.
   / Been looking for 5L Vee belt pully to direct mount on Hydraulic pump TAPER Shaft #9
Can you make a shaft adapter, tapered inside, straight outside to fit your pump ?
I've done so already, and would rather not do so again if the need for an alternate pulley size should arise.
By the time you get the taper dialed in, and the keyways cut, There is way more time in the piece than a $20 pulley.
(3) STEEL CARTS (A51248)
(3) STEEL CARTS...
2020 JOHN DEERE R4023 LOT IDENTIFIER 87 (A53084)
2020 JOHN DEERE...
2009 GMC Passenger Van, Vortec Engine (A52384)
2009 GMC Passenger...
UNUSED RAYTREE REDM32-32" EXCAVATOR DRUM MULCHER (A51248)
UNUSED RAYTREE...
2014 Dodge Ram 5500 Chevron Wrecker Tow Truck (A51692)
2014 Dodge Ram...
2025 INDUSTRIAS AMERICA FT510 5'X 10' HYD DUMP TRL (A51247)
2025 INDUSTRIAS...
