Beaver 3pt question
   / Beaver 3pt question #1
SteveM
Upstate NY
Kubota B7100DT
My Beaver (370) 3pt lift seems too fast, very jerky - much faster than any other tractor I have owned. I dont see a flow adjustment under the seat, is there anything external that can be adjusted?
Back blading is very tricky as I can only lift in 3-4inch jerks - shakes the whole tractor. On the positive, it lifts very heavy implements with no resistance!
Note, this tractor has a Johnson Workhorse 10 FEL plumbed from the gearcase; could that be a factor?
Second question - The Johnson loader has down pressure to easily lift the front wheels, yet it only will lift about 300lbs of dirt - and begins to squeal lifting anything more than 200lbs. Is that normal? Should I have the valves serviced?
   / Beaver 3pt question #2
I have a Beaver that does the same thing on the 3 point. I have a belly mower and 3 point that works off the same lever and both are real jerky. I just figured it was the nature of the tractor. I am getting ready to change the fluid in mine and will let you know if that did any good.
   / Beaver 3pt question #3
Well I changed the fluid in the beaver and it didn't help a bit with the jerky 3point problem as a matter of fact it went up and would not come back down. I am trading it off Monday for a Yanmar F16D. I hope I made a wise choice as the Beaver has been nothing but trouble from day one.
2024 40 ft. High Cube Shipping Container (A53117)
2024 40 ft. High...
14ft trailer 12 ft deck (A51694)
14ft trailer 12 ft...
UNUSED HURRICANE F10 10' WROUGHT IRON SITE FENCE (A51248)
UNUSED HURRICANE...
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
2025 Mower King SSRC (A50123)
2025 Mower King...
2015 Ford Escape SUV (A51694)
2015 Ford Escape...
