bearing without axial tilt
   / bearing without axial tilt #1
wwwfarmer
I am building a simple root crops harvester attachment. The attachment has cutting discs in front of it to prevent weeds from jamming it. This is the almost finished machine.
The problem that I am facing is that the bearings I used are not stiff. That is, they tilt on the shaft axis along with cutting discs. I want the cutting discs to be straight. To counter act that, I can use 2 bearing as shown in the image below. The problem with this approach is that my shaft is pretty short (it barely fits 2 bearings) and I lose the option to position the disc left and right on the shaft.
How do plows, harrows or potato harvesters attach cutting discs? Is there a special type of bearing (and bearing housing) that prevents tilting? Should a bushing be used instead? Thank your for your answers.
   / bearing without axial tilt #2
It sounds like you have self aligning bearings. The OD of the outer race has a spherical radius ground on to it that matches the spherical radius on the housing. In order to use a single bearing on one side of the disk, you need a cylindrical race OD. You also may want to consider a roller bearing instead of a ball bearing for greater radial load capacity. But i would caution you about the side (or twist) load on the bearing when mpuntide to 1 side of the disk. You may want to consider placing the ball/roller bearing on the centerline of the disk and retain with 2 half depth covers. In this case the hole in the disk is the OD of the bearing. But this may require making the bearing retainers.
   / bearing without axial tilt #3
On some plows, they use a spindle attached to the plow with a hub with a couple of tapered roller bearings that the disk bolts onto.
A cheap utility trailer axle spindle and hub would work fine for your application.
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
2014 Ford Fusion AWD Sedan (A56859)
2014 Ford Fusion...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2018 INTERNATIONAL...
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
2003 Big Tex 10PI...
2018 Nissan Pathfinder SUV (A56859)
2018 Nissan...
