Bearing removal from RS1400 tiller
   / Bearing removal from RS1400 tiller #1
rmully
North Carolina
YM 2020
I found a hole on the bottom of the bearing cover on the non gear side of this RS1400 yanmar tiller. It was full of dirt and the bearing needs to be replaced. I can't seem to get the bearing out used PB Blaster on it for days and there is not enough space to get a gear puller under the outer race. Anyone done this and have any tricks? Do i have to pull the whole axle out?
Thanks
Robert
   / Bearing removal from RS1400 tiller #2
I would try using a Gear or Bearing puller that you can reverse the Arms so they grab out instead of in. I have a set of Harbor Frieght EL-CHEAPO'S that will Reverse and in 3 differnt sizes. I believe I gave 20 Bucks for the set. ;)
Carey
I rented a set from Advance Auto but even the smallest set reversed was too large.... Casey did you use the Harbor Freight set to remove the bearing cause if so i will go get a set.
   / Bearing removal from RS1400 tiller #4
I have an RS1300 tiller which I expect is very similar to yours. Having looked at the bearing housing you are speaking of I have an idea if it is like mine. There are three larger bolts that hold that little bearing housing to the tiller frame. If you removed those three bolts I believe your shaft could drop beneath that frame enough to allow putting a puller on the back side of the little bearing housing. You could pull housing, bearing and all I'm assuming you removed a snap ring or lock nut on the shaft when you removed the outer bearing housing cover. Might even be able to get 2 pry bars in between tines and housing to pry it off. May not be like the rs1300 but might look at the possibility.
   / Bearing removal from RS1400 tiller #5
Thank goodness I was able to clean mine up since I caught it. Thanks to Member California making a post of it :D. But to answer your guestion yes my smallest puller will fit no doubt but I was able to clean it up while it was still in it. Just a rag and parts cleaner and blew it out with a compresser. Okay don't laugh I'm a tight wad but just repacked it with my EL CHEAPO grease packer from again HF.:laughing: It worked but PMO since I just bought it and new I better look from all the other Dumb A_ _ things that was wrong even the PTO shaft was wrong the RS1400 is the tiller made for a YM 2000 and it came from one of the Largest co. in the US. :ashamed:
   / Bearing removal from RS1400 tiller #6
If your bearig is bad than don.t worry about tearing it up any more just remove a couple of ball bearings and your puller should fit. So while I have these old picks out. Check out just how bad the wrong shaft was. I had to remove so much and had to cut out and weld it back together. and if you look hard enough you can see I even had to cut off the female side of the shaft. They finaly gave me another Shaft it just took them 2 Wks. and I got tired of weighting for it and thats how I was able to catch the bearing also. :confused:
Carey
Thanks Winston and Casey ...I will try removing a few ball bearings to get some room and try the puller i rented otherwise I can see removing the 3 bolts would give me space ..I will let you know what happens.
Taking off the 3 bolts worked because the bearing housing could spin around and i could bang the housing and bearing off the shaft. This still left the problem of the bearing in the housing but I was able to get the inner race out after digging out the bearing retainer. I had to take the bearing housing to a machine shop and they welded a bar to the outer bearing collar and put it on a press and pushed it out. Had to go to a bearing house for the replacement and got a sealed SKF bearing for $38 that will out live me. The tiller is back together and runs great. Now all i have left is making the rear skirt (got the metal today) and I am done. I have under $600 into the tiller including the $300 I pain for it so I still feel like i got a great deal. Thanks for all the help guys!! Yanmar people are great ...the guy I got the steel gave it to me free because he used to own a Yanmar and loved the tractor.
   / Bearing removal from RS1400 tiller #9
Great RMully. That was one of the reasons and Glad of it for sure now of checking mine. Thanks again Cal. I still have 75$ more in mine some repair work and a road trip to AL. My opiniun is plain neglect from the rice patty's but like you caught it all before it wasn't worth fixing it. Prob.out last me also now.
Carey
2019 Top Hat Industries 18FT T/A Utility Trailer (A52377)
2019 Top Hat...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
2000 GAL FUEL TANK (A53843)
2000 GAL FUEL TANK...
CAT FORKS W/ QUICK CUPPLER ATTACHMENT (A53843)
CAT FORKS W/ QUICK...
