Bearing Identification
/ Bearing Identification #1
Giles
Florence Alabama
2009 Kubota B2320---Wheelhorse lawn mower--- Case 480D Backhoe
I am in need of about four flat idler pulleys. They are no longer available and I have searched extensivly! All have bad bearings that are sandwiched between the pulley halves. I removed the rivets and found the ball bearings have no identification numbers.
They are 1.575" OD by .500" thk. and the ID is 3/8" that a 3/8 bolt passes through.
What do you call a bearing like this that doesn't have a precision ID?
/ Bearing Identification #2
I think you will find that you may have to buy the pulley with bearing in it? Ken Sweet
/ Bearing Identification #3
Are you sure the 3/8 ID is not a sleeve inside reducing it to that? Or could you put a sleeve in it to reduce it to 3/8? I found that a 6203 bearing is pretty close, but is 7/16 inch thick, not 1/2. but does not have 3/8 ID
/ Bearing Identification #6
Do you have local farm stores? They will probably have a very close to original fit that should work.
/ Bearing Identification #7
If all it is, is a flat idler pully, all that matters is the radius and the width. The bore is just a bolt size.
A brand or mower would help. Identifying English or metric would help, too, just to get a bearing.
Otherwise, AgriSuppy or TSC, or Grainger, or a JD, Kubota, Ford, NewHolland dealer (etc).
I'd buy the whole assembly instead of putting it all together.
I have checked local and did a google search on what little info I have. I don't even know what this machine is called. It is so weathered I can't make out any name or numbers.
It doesn't belong to me, it is owned by a friend. He called me to see if I could help and I am thinking it is a useless search trying to repair a piece of scrap. (Maybe I will tell him that:thumbsup:) I will try to get more information and a photo.
Just trying to help a friend:)
/ Bearing Identification #9
Sounds like something simple enough you may find it at the local TSC. Though maybe I don't understand completely. If you don't know what it is, how do you know the pulleys aren't available any more?
/ Bearing Identification #11
I am in need of about four flat idler pulleys. They are no longer available and I have searched extensively! All have bad bearings that are sandwiched between the pulley halves. I removed the rivets and found the ball bearings have no identification numbers.
Bearings come in standard sizes. What's best is to find the number on the bearing itself. Does it have shields? Usually the bearing number is on the shield. The other question I have is how are you measuring the bearing? Did you use a micrometer? If not it may be a metric bearing. Is the bolt metric or inch, are you sure? Chances are the bearing is readily available but we need to know the exact dimensions especially if it's pressed in.
Rob
2016 Peterbilt 579 Day Cab w Hydra Flow Setup (A62613)
2016 Peterbilt 579...
2006 Ford F-150 Ext Cab Pickup Truck (A61573)
2006 Ford F-150...
Forklift (A56857)
Forklift (A56857)
1980 FRUEHAUF 45' T/A FLATBED TRAILER (A59910)
1980 FRUEHAUF 45'...
17109SFL (A61569)
17109SFL (A61569)
2 Row Cultivator (A64047)
2 Row Cultivator...
