Flail Mower Bearing Clamp Bolt Mott 72Flail.
   / Bearing Clamp Bolt Mott 72Flail. #1
EdwardB
Michigan
JD 4410
I am having problems with the bearing clamp bolt for the main shaft on my Mott 72. It wants to loosen up and has actually fallen out once. I tried blue thread locker, but it did not work. Maybe I didn't use enough. There are no unexpected vibrations at 540 operating speed. Any suggestions?
   / Bearing Clamp Bolt Mott 72Flail. #2
Any way you can drill the head and safety wire it?..................Mike
That is a great idea! Unfortunately, the bolt itself is screwed into the shaft and spins with the shaft when running (unless something is seriously amiss here).
I'll snap some pictures tonight.
Deere 9970 Cotton Picker (A53472)
Deere 9970 Cotton...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A51694)
2022 K-Z Sportsmen...
2015 Ram 4500 Utility Truck, VIN # 3C7WRKAJ9FG707673 (A51572)
2015 Ram 4500...
2022 CASE 580 SUPER N BACKHOE (A51246)
2022 CASE 580...
