Chipper bearcat chipper problems
   / bearcat chipper problems #11
Tractor does not bog down it is the flywheel and blades. I opened it up and and I can pretty easily turn it by hand.
If the tractor is not bogging - you should have smoke pouring off the belt. Atleast that is what happens with mine. Any smoke?
D.
   / bearcat chipper problems #12
I think there is a spring loaded idler pulley that tensions the belts.Is it there and tensioning the belts? It is possible that someone switched to incorrect belts? You can download the parts manual from Echo/Bearcat. Jason it right on about the blades. If you touch them they will cut you if they are sharp. Did you mean model 73554? My Bearcat (70554) will stop the tractor engine before it bogs down.
Chris
   / bearcat chipper problems #13
Chris
There is a tensioner.
I can bring my tractor to it's knees also, but it depends on how the load is applied. If it is a gradual load increase like chipping a big log and the rotation speed slowly decreases - the tractor slows down and I suspect would stall if I didn't stop the feeding of the material.
If the load is immediate - the belt will slip and start smoking.
D.
   / bearcat chipper problems #14
I have a Bearcat 5 " PTO chipper but I am not sure of the model. I would have to go look. If you ask Bearcat they would probably send you a manual for it. Belts are important,knives and anvil adjustments are also. The knives are reverseable. If they have never been turned over then do so.
Thanks, I will check the blades again and make sure they are sharp and take a better look at the belt. The blades seemed pretty sharp before. The chipper has around 10hrs of use. With big logs/limbs it chips great at the very start and then just a little in it bogs down. I can see the pto shaft spinning but flywheel slows down drematically. No smoke from the belt. If I take the large limb out of the chipper the flywheel will regain regain speed and clear the debris left in the chipper.
   / bearcat chipper problems #16
10 hours is about the time I would be thinking about sharpening my knives in a manual feed machine. My bearcat has 4 knives. 2 inside and 2 outside which can be swapped to get a few more hours of chipping. Some of the newer bearcats have double sided knives which can be turned over.
Let us know what you find.
Chris
   / bearcat chipper problems #17
If your blades are sharp then check the clearance of the blades to the flywheel. If its too high, the machine will want to grab more. What I do sometimes is when the blades are newly sharpened (enough to take the hair off the arm) I set the clearance low. Then as the blades dull a bit, if I don't have time to sharpen, I open up the clearance so it continues to cut at about the same rate. HP and belt tension are importance, but don't forget about blade clearance.
Its like sharpening the teeth on your chainsaw, if you don't have the rakes filed to the right height, it won't matter how sharp the teeth are, the saw won't cut proper.
   / bearcat chipper problems #18
You might want to check for a sheared key between the pulley and the shaft. There could be enough friction to spin the flywheel up to speed with no load, but not maintain drive under load.
PALLET OF SPRINGS AND U BARS (A55745)
PALLET OF SPRINGS...
2017 PETERBILT 579 DAYCAB (A53843)
2017 PETERBILT 579...
40' CONTAINER (A51244)
2018 PINSA 130BBL VACUUM TRAILER (A53843)
2018 PINSA 130BBL...
2002 POLAR TANK CRUDE TRAILER (A55745)
2002 POLAR TANK...
2022 John Deere 5065E MFWD Tractor (A53485)
2022 John Deere...
