Bear damaged sweet corn? (pic)
/ Bear damaged sweet corn? (pic) #1
Oleozz
Pa.
International 1066 with Year Round Cab, Kioti DK 45S with Cab, 451 Loader
Fairly sure it's not coons, just several big areas mowed down, stalks ripped off and the corn chewed off. Hopefully it's in the next county by now.:)
/ Bear damaged sweet corn? (pic) #2
Yes, bear damage. I see alot of it, usually they will clear a large area so beware. We had two different boars in the field accross the street a "very steep incline" work on that field all summer last year. From 300 yards it looked like each one cleared a quarter acre. The are almost better than a combine.
Brad
/ Bear damaged sweet corn? (pic) #4
Wow! That's some serious damage. I also noticed how gravelly your soil is. It looks like there is no chance of seeing tracks. Does all your soil have that much gravel?
/ Bear damaged sweet corn? (pic) #5
No, usually in Pa soil, there's more rock. That soil is quite clean.
What you call gravel we call "flinty ground." When you look at it there seems to be more stones than soil but the soil is there. This type of ground holds the moisture very well and grows nice corn and potatoes. It is tough on farm equipment such as plows and discs. Only certain parts of the farm has that type of soil and that's where I try to grow the sweet corn.
/ Bear damaged sweet corn? (pic) #7
I've seen deer do that kind of damage. Once walked a corn field probably 8-10 acres in size and there was a 50 yard sort-of-circle well into it that was just flattened. They apparently were living and feeding there.
Look at the path in/out. Deer can walk the rows coming and going with no damage. Perhaps a bear could, but I would think a bear would tend to leave damage coming and going.....but then I've never seen a bear walk a cornfield so it would be only a guess.
That makes sense LMTC. Most of the deer damage that we have is with the young stalks, especially during a dry spell. They will come in and chew the tops off the young corn, I'm assuming partly for the moisture content of the corn.
/ Bear damaged sweet corn? (pic) #9
Oleozz said:
What you call gravel we call "flinty ground." It is tough on farm equipment such as plows and discs. Only certain parts of the farm has that type of soil and that's where I try to grow the sweet corn.
Good Evenin Oleozz,
Sorry to hear about your corn field visitors !
But that IH 1066 must do a nice job plowin and discing ;) up that cornpatch ! :)
scott_vt said:
Good Evenin Oleozz,
Morning Scotty----Actually damage has not been bad, just several areas in one patch and some stalks torn down in another. I think the predator eyes do help and I move them every other day. We have been blessed with a good harvest this year, rain when we needed it and hot humid nights during the growing period.
/ Bear damaged sweet corn? (pic) #11
When I used to live in northern Minnesota I had a chance to see a lot of corn fields damaged by bears. Most of what I saw they would drag the whole stalk back into the woods and eat the corn there. There would be hundreds of stalks right on the trails going back into the woods. They can definitely do a lot of damage.
/ Bear damaged sweet corn? (pic) #12
I still would not count out coons in your corn patch. I have had them hit the corn in the past and it looked like a major tornado had hit the place / patch.
2004 John Deere 310G 4x4 Loader Backhoe (A59228)
2004 John Deere...
Ofa Eko 8 studded tire chains
Ofa Eko 8 studded...
2014 UTILITY 53X102 DRY VAN TRAILER (A59914)
2014 UTILITY...
2001 Sterling Single Axle Dump Truck (A62613)
2001 Sterling...
2008 GMC 4x4 Ext. Cab 9Ft Flatbed Pickup Truck (A64194)
2008 GMC 4x4 Ext...
2012 Ford F-350 4x4 Ext. Cab Pickup Truck (A61568)
2012 Ford F-350...
