Bead locks Tire removal help
   / Bead locks Tire removal help #1
bjr
Eastern WA
Jinma JM354
I have the Harbor Freight manual tire post machine and for passenger car tires it does okay. A buddy's son came by with a 8 or 9" in diameter ATV tire from a quad runner Honda and it had bead locks on the wheel. I tried all my tricks like soap water on the wheel and even tried the big tire slid hammer and for the life of us could not get the wheel bead to break. What do you guys do the break loose the beads with the bead lock bump groove on the wheel? bjr
   / Bead locks Tire removal help #2
Dunno if it will work for you, but I've had good luck in using my vice to squeeze small tires enough to break the bead. Done this with 8" garden tractor tires that had the wheel rusted and bonded to the tire...
Might work for you...
VICOR HAY CUTTER (A58214)
VICOR HAY CUTTER...
1999 Volvo WG T/A Dump Truck (A55973)
1999 Volvo WG T/A...
MACK T/A DUMP TRUCK (A58375)
MACK T/A DUMP...
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A55745)
2012 NORAM POWER...
2008 Ford Fusion SE Sedan (A54815)
2008 Ford Fusion...
2015 Peterbilt 367 National Crane NBT55 5-Mast 128ft. 55 Ton Quint Axle Crane Truck (A55973)
2015 Peterbilt 367...
