Rake BD2F Doser
   / BD2F Doser #1
xflyhighx
Bushnell, Florida
BD2F
Is a root rake worth the money on a small dozer or am I dreaming. I need to clear brush in Florida and then make piles to burn....some say it won't have the HP to do it and then some say you'll be fine....please help....thanks in advance.
   / BD2F Doser #2
A lot will depend on what you mean by brush. Being in Fla you probably have soft ground which will help. At 37 hp and 9000 lbs you wont be tearing up trees but brush maybe. Try tipping your blade and running through the area with the corner down in the roots to get an idea of what your machine can do in the area you need to clean. Remember you can always take smaller bites with the rake as long as you can lift the roots and they wont stop you.
Otherwise hire it done or rent a bigger machine.
   / BD2F Doser #3
I have a similar machine, a Komatsu d20. I don't have a root rake but I have no problem taking down pretty big trees, just takes a little longer. I'd think if you keep the teeth short and spaced wide a root rake would do fine. In Louisiana we have pretty good ground so that's what I'm basing my opinion on. Moisture will make a difference too. Up north in the rocks, probably won't work.
John Deere D110 42in Riding Mower (A49461)
John Deere D110...
2017 Wacker Neuson ST31 Compact Track Loader Skid Steer (A49461)
2017 Wacker Neuson...
1997 HUBBLER BROS. LOGGING TRAILER (A50854)
1997 HUBBLER BROS...
2015 KENWORTH T800 MID-ROOF SLEEPER (INOPERABLE) (A50854)
2015 KENWORTH T800...
Zero Turn Mower (A48082)
Zero Turn Mower...
2016 Case CX55B Mini Excavator (A49461)
2016 Case CX55B...
