BCS850 won't start
/ BCS850 won't start #1
Tractorganic
Lower CT River Valley/US/Blue Moon Farm
NH/TC40D SS; BCS 850, Brush Mower, Sulky, 'Tiller, Chipper, Snow Blower; JD X570-48-A
Was running the snow blower attachment on my 850 back and forthat a mean snowdrift. Flipped into rev. one last time , heard high p[itch grind noise and it died. Auger spins freely, it's out of gear both pto and drive trany, but no start. Fuel is full, carb doesn't smell fuely, pulled plugs and pulled the cord several times to stop flooding. Almost starts on 1'st pull but then it's just an exercise machine. Any help welcome. I'm in CT which has suddenly become arctic and plow trucks just make garage glaciers!
/ BCS850 won't start #2
Hi! Your BCS 850 engine is not winterized. I think May be carburator engine is frosted by very cold air. Here a trick of mine. I put a heavy blanket over engine and in same time I put one electric spotlight under engine. For about one hour. Engine start and run very well. Good Luck Oldmech
Thank you Oldmech but still same problem after warm up. It gave a pretty good purr then died and wouldn't make any starting sounds after that. I checked the kill-switch circuit manually and unplugged/replugged the spade connector but as said, no good. This is serious, now I can't get to my wood pile but; I "should" get my New Holland tractor back from service this week (yeah, sure). Getting new tire chains, a little late, huh?
I can't believe I get to complain to someone from Quebec about snow stuff. We've more snow here in Connecticut than Quebec and more is on the way!
Oh well it's the poor man's mulch hey?
Chris,
Farming organically for 30 yrs. at Blue Moon Farm
/ BCS850 won't start #4
What make engine has it got? Honda? I have a Yamaha ATV that will all the sudden just refuse to start. Its always been the spark plug. I first will notice it just takes a tad longer to start then like a lightswitch it refuses to turn over. I'll put in a new NGK plug and it fires up and runs great. The old plug will look "ok" but it is shot. I used my ATV lots and a plug will last about a year and a half. If you've not changed your plug I would remove the old plug. Put about a teaspoon of gas in the cylinder, put in new plug and then see how it runs.
It's a Brigs + Straton V twin and last fall had new NGK plugs.and fuel filter.The fuel is special high octane no alcohol Small Engine Fuel I get in 5 gal. cans.
I'm clueless 'cuz it ran well for about 15 min. in the cold then quit.
Thank you,
Chris
/ BCS850 won't start #7
Hi! After engine dies Check for sparks if good sparks may be Frost in carburator. Check also air vent in gas cap. If no sparks May be coil or electonic module faulty.
For snow in Quebec You are right! I just clean my drive way 4 times. We are jealous of you! Good luck! Oldmech
I'm going to the repair shop tomorrow and will ask if the SEF94 fuel that I use requires any antifreeze. It is 94 octane w/ no alcohol so it doesn't suck up moisture, but I'll ask.
I will look into plug test and possible coil or electronics probs.
Thank you everyone!
Chris
/ BCS850 won't start #9
Hey Chris,
The high pitched whining is because the reverse didn't fully engage. This should not have killed the engine, though. I think they're mutually exclusive problems.
I had a V-twin Briggs on my 850 before I mounted a Kohler (lombardini) diesel and didn't like the engine at all. It sure sounds like you're describing a fuel delivery problem. Perhaps there was a little water in the gasoline tank? There's a way to drain the fuel outta the carb float bowl, I just can't remember how. It's gotta be some sort of screw or petcock and tube on the bottom of the bowl. Sorry, I can't be more specific, but I dumped that engine two years ago. Also check for kinks in the fuel line and see if there's a fuel filter on it. Another remedy in to use a little "HEET" in the fuel. It's just adding alcohol - what you apparently didn't want in your fuel in the first place - but it may work.
Another thought - does it have a low-oil sensor? Of so, check for oil level and unplug the sensor once you determine it has enough.
The best remedy is to take it off and buy a Koher diesel! :)
Bill in WI
It turned out to be a piece of dirt caught in the carburettor. An economical fix; but a major pain with downtime during snow and ice storms forcing us to shovel and chop ice!
Thank's everyone,
Chris
/ BCS850 won't start #11
Thanks for letting us know what happened. I own two of these Mr. Funnel filters and strongly recommend you get one so as to prevent this from happening to you in the future. I have kerosene heaters as emergency back-ups and because the fuel maybe stored for years, it has not been a problem because of these water and particulate removing funnels. Note: Am not affiliated with Mr. Funnel but do own the smallest and the largest versions. I bought mine via Amazon use them for all fuels, diesel, gasoline and kerosene. I got them to remove water from fuel and have found there is also particulate matter that sometimes gets into my fuel tanks as these filters show the stuff that is removed!
Home
Bill in NC
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
Ford 8210 (A60462)
Ford 8210 (A60462)
Year: 2011 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 118,735 Plate: Body Type: 3 (A59230)
Year: 2011 Make...
2006 John Deere 325 Skid Steer (A63116)
2006 John Deere...
2020 14ft. Continental S/A Boat Trailer (A61569)
2020 14ft...
UNUSED SDLANCH 12' X 20' METAL LIVESTOCK SHED (A62131)
UNUSED SDLANCH 12'...
