BCS two-wheel tractors - factory quality issues, bad support
   / BCS two-wheel tractors - factory quality issues, bad support #11
If BCS is as expensive in the EU to buy as the prices I was quoted in the USA, I have some sympathy for the OP experiencing any leakage. Didn't end up buying because it seemed like so much money for a 2 wheel machine.
   / BCS two-wheel tractors - factory quality issues, bad support #12
I purchased my 853 for $3,300 used and it came with a rotary plow, it was well worth the cost.
   / BCS two-wheel tractors - factory quality issues, bad support #13
the term "tractor" in this instance is definitely stretching it. :geek:
Disagree, it is certainly a tractor and if you look up the definition of tractor it even says 2 wheel walk behind.
   / BCS two-wheel tractors - factory quality issues, bad support #14
This is the generally accepted definition. One problem with modern society is the tendency to redefine terms to suit feelings rather than facts.
   / BCS two-wheel tractors - factory quality issues, bad support #15
There is a sub forum dedicated/titled as "two wheel tractors", which is where this was correctly posted.
   / BCS two-wheel tractors - factory quality issues, bad support #16
My Defunct New Holland dealer sold BCS tractors and I agonized over buying one until I found out what they cost. The one he had on the floor was a Hatz diesel. Back then it was insanely priced. Don't remember what it was but when I found out the price, I walked away. Long time ago. I don't believe you can get them with the diesel today, just a Honda gas motor. Hatz builds a bullet proof compresion start low powered, air cooled diesel engine.
   / BCS two-wheel tractors - factory quality issues, bad support #17
   / BCS two-wheel tractors - factory quality issues, bad support #18
Wikipedia is not a source. Calling them tractors is a serious stretch.
Show 100 people pictures of both and ask which is a tractor.
   / BCS two-wheel tractors - factory quality issues, bad support #19
So all of these sources are wrong your saying? Brave Search
   / BCS two-wheel tractors - factory quality issues, bad support #20
I said what I said. These are not tractors in the normal usage. Wikipedia is not a source. Both of these things are objectively true.
Year: 2017 Make: Ford Model: F-550 Vehicle Type: Truck Mileage: 109,098 Plate: Body Type: Super Cab (A59230)
Year: 2017 Make...
FUEL PUMP W/NOZZLE (A58216)
FUEL PUMP W/NOZZLE...
More info coming soon! (A56858)
More info coming...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A56438)
2012 MACK Tender...
20 X 20 CAR PORT (A58214)
20 X 20 CAR PORT...
2 Disc Heavy Duty Bottom Plow (A57454)
2 Disc Heavy Duty...
