BCS two-wheel tractors - factory quality issues, bad support
   / BCS two-wheel tractors - factory quality issues, bad support #1
trac174
EU
BCS PowerSafe
A few years ago, I purchased a brand-new BCS-738 Powersafe with Honda GX270. I reckoned that buying a new tractor, not a second-hand one, might be a life-long investment with my little use in a garden. Now, when the warranty expired, I see how was I wrong.
From day one tractor had an oil leak. Using the tractor 1-2 times a year the leak was not a big problem. During a year I can collect about one liter of transmission fluid leaking. The leak was in a junction between GX270 and Powersafe clutch. That indicates an issue with factory assembly process and quality control. The level of transmission fluid may be critical for a proper operation of Powersafe clutch. When warranty was close to expiring, I decided to take a chance and try to fix the problem with the help of BCS blessed local services.
For a long time, it was not possible to arrange a visit of a mechanic to see the tractor and identify the problem. Without such they won’t consider it as a warranty case. Additionally, they declined to sell me BCS oil filters. Without any success, I wrote a message using feedback form on the official BCS web site bcsagri.com describing my problem and asking help in finding a reputable local service in my country. After submitting the form I've got "Thanks, we have received your information! We will contact you as soon as possible".
In 3 months, however it was not possible for BCS S.p.A. to contact me. Clearly, the warranty has expired. Out of curiosity, I wrote again to BCS S.p.A. wondering if that channel works. In a few days, the answer came from someone in Divisione Abbiategrasso by name Luca Locati. He was very helpful saying that no message from me was ever received, misspelled my tractor model and assured that same people I was in contact with call me soon.
Basically, this is the end of my story. No one contacted me. Without even asking possible repair cost, I assume that 1 liter of most expensive transmission fluid in a year will be less costly solution to continue using my tractor. Additionally, I found that the BCS S.p.A. policy for appointing random companies for local support, may create more troubles to my tractor as a result of their repair compared to simply refilling the oil regularly.
Concluding, you may be lucky if your newly bought BCS 2-weel tractor works trouble-free. If not, you may have difficulties in its warranty repair. When warranty expired, buying spare parts can be a problem too, as for example Ferrari-named oil filter costs a treasure at some resellers. Perhaps, for me the best solution would be to get rid of my tractor and seek a new one from more established brand if someone would recommend me such.
   / BCS two-wheel tractors - factory quality issues, bad support #2
Please contact Joel at www.earthtools.com he is the main importer for BCS and Grillo in the USA.
Joel would be of greater help to you in solving this for you as he has a very good reputation with
BCS and could help you wade through mess of lost communications and service needed for your
BCS tractor.
I am sorry you are going through this.
   / BCS two-wheel tractors - factory quality issues, bad support #3
BCS tractor.
The man with the problem is not in the USA.
   / BCS two-wheel tractors - factory quality issues, bad support #4
I understand that, I suggested he contact Joel as he was not being
helped by anyone in Europe.
   / BCS two-wheel tractors - factory quality issues, bad support #5
If I was using a piece of equipment only 1-2 times a year I would look at renting.
Also the term "tractor" in this instance is definitely stretching it. :geek:
738 PowerSafe Bcs
   / BCS two-wheel tractors - factory quality issues, bad support #6
Welcome to TBN. A great place to B#$ch about issues that should've been dealt with another way.
"From day one tractor had an oil leak."
Did you contact the seller? Why wait so long to escalate the issue?? You'll now have to just accept it and deal with the leak, for fix it yourself. Leaks aren't really hard to diagnose.
   / BCS two-wheel tractors - factory quality issues, bad support #7
^This is the best lesson. When you have a problem with a warranty type issue, get on it as soon as possible. Companies always seem to drag them out.
@tradosaurus Agreed. My personal minimal definition is at least 4 wheels with a PTO and a seat.
Also, please change your profile pic. She's making me ill. šŸ˜€
   / BCS two-wheel tractors - factory quality issues, bad support #8
Greta is the poster child for everything that is negative about going green. Kind of like David Hogg is the poster child (he's an immature brat) for everything political that is wrong as well.
I pay neither of them any mind in reality.
   / BCS two-wheel tractors - factory quality issues, bad support #9
In reality, I would prefer to use the MG42 sub machine gun as my Avatar but I felt that it would offend too many of the thin skinned commenters on this site, so I didn't. I owned one a while ago, it's a C&R approved weapon. 1200 rounds per minute in full auto and capable of 1500 rounds per minute of you lighten the Mauser diuble claw extractor. 1200 rounds of belt fed linked rounds today is expensive enough.
Maybe I should change mine to reflect my hobby.
   / BCS two-wheel tractors - factory quality issues, bad support #10
At one time I considered a Hatz powered BCS to work my garden, they are nice units but if I owned one that leaked, I'd be taking it apart and resealing the leaking joint. I don't as my Cub Cadet, Honda powered rear tine tiller works for me and I put on the hiller attachment when planting potatoes.
Terex TB44 44ft Telescopic Boom Lift (A55851)
Terex TB44 44ft...
2008 Genie S-65 65ft Telescoping Boom Lift (A53421)
2008 Genie S-65...
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
2019 Bobcat 3400 4x4 Utility Cart (A54811)
2019 Bobcat 3400...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A56129)
2006 KENWORTH T800...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
